Lyrik U-turn stuck low speed dial- Mtbr.com
Results 1 to 3 of 3
    Jun 2005
    I have a 2009 Lyrik U-turn Mission Control. From start all dials worked well but after a oil / bushing change the Low speed compression dial got stuck after a while. Now I can only turn it 1/4 of a turn.
    During the rebuild I made a mistake when I looked up the oil volumes on the net. I got hold of a 2011 manual stating 193ml in upper leg. I then found out that I should only have poured in 112ml in my "old" forks.
    Any advice on how I can get the low sped dial working again?
    Is it likely that the excessive oil caused the trouble?
    Hope to get some help. RS service is non existant in Sweden!
    Cheers!
    moaaar shimz
    Reputation: tacubaya's Avatar
    Remove the cartridge, disassemble and analyze what is getting that dial stuck.
    Jun 2005
    I have had the cartidge removed. I can se how the high speed dial effects the cartridge, while the low speed seems to be a more "internal" function. IŽm afraid IŽusure IŽll ever get it together back again.
    Split chart anybody?
  1. high speed compression dial frozen (coil Lyrik)
    By Horacek in forum General Discussion
    Last Post: 08-30-2011, 06:43 AM
  2. 07-09 Lyrik U-Turn Spring Kits fit 2010 lyrik r coil ?
    By jiabin172 in forum Shocks and Suspension
    Last Post: 07-05-2011, 08:55 PM
  3. Avid Speed Dial 7 vs Speed Dial Ti levers
    By fireroad in forum Brake Time
    Last Post: 03-28-2011, 09:42 PM
  4. Avid Speed Dial 7 vs Speed Dial Ti
    By Call_me_Clyde in forum Brake Time
    Last Post: 01-14-2011, 03:03 AM
  5. Replies: 8
    Last Post: 07-16-2008, 01:21 PM
