Lyrik RC2 DH vs. Float RC2?- Mtbr.com
    Fat Skis/Fat Tires
    Reputation: rangerbait's Avatar
    Why is it so difficult to find reviews on the 2012 models of either of these forks? You see them EVERYWHERE, yet aside from like 4 reviews of the Fox and ZERO reviews of the Lyrik here on MTBR, they seem to not exist.
    Am I just not searching the right areas?
    Anywho, I'm building a 2012 Turner 5 Spot and am trying to decide between the Float and the Lyrik, 160mm.
    I'm 6' 4, 205lbs. and like a lot of resistance to brake dive, lots of small bump compliance, good rebound after loading the fork up, and a healthy amount of ramp up at the end of the travel.
    I don't want to constantly be effing with the damn thing either; ain't nobody got time fo dat.
    Thoughts?
    Can't help on '12 but I put a '11 Lyrik RC2 on my Butcher, I'm close to your size and its been great, dialled in the air pressure set up the rebound/compression and not touched it since.
    Mar 2006
    I ran a 2011 Float 180 RC2 for a season and a half, and I'm dumping it for a coil Lyrik dh as of today.
    I don't believe there are any substantial changes between model years, definitely none for the chasis.
    I suffered from the semi-bath oil migration issue the entirety of 2011, and had to rebuild the fork monthly to maintain proper bottom out performance. Fox finally fixed this issue last December by adding a scraper in addition to the air seal on the piston.
    It's difficult to achieve 30% sag on this fork without having it dive. You can get it to have reasonable mid-stroke support, but at the cost of messing up your bike's geometry.
    It is a very stiff fork, that's probably the best thing it has going for it. BUT, and this was the deal breaker for me, Fox's CSUs develop a creak at the stanchion crown interface. Cracking noises like this drive me insane, and don't inspire confidence through the chunder. I went through two CSU's and now I'm done.
    It's a b!tch to service the damper. No doubt about it. I did it once successfully, but gave myself arthritis in the process. My buddy says he can change the damper oil in his Lyrik in 15 minutes, which is a huge selling point for me.
    Rebound range is very good on this fork, the LSC range is not effective, and the HSC does its job.
    Quote Originally Posted by half_man_half_scab View Post
    I have the same experience you're talking about with my talas 160 where its hard to get the proper sag without it diving pretty badly. it hasnt been a huge issue because my bike seems to ride best settling into its travel a bit front and rear. its fine when you're charging through something, but when it gets technical or you need that support its pretty annoying.
    im looking into a lyric as well as the 44 rc3 ti, and BOS Deville, leaning towards the BOS. id consider a push'd float 160 as well.
