Lyric Ultimate Questions- Mtbr.com
Results 1 to 3 of 3
    I'll keep this tight. Wife's new scooter has a 150mm Lyric Ultimate. SHe wants to know what the control knobs on the right side do....I cannot feel any difference when altering their settings.
    • Does it have lock out?
    • Slow speed compression should be turned up in what type of trail surface or riding
    • High speed compression should be turned up in what type of trail surface or riding?
    Cheers!
    Mar 2012
    No lock out.
    LSC, the small dial, helps control fork dive actions like braking or weight shifts. It also affects how sensitive the fork is to smaller trail chatter. For steep trails, I may add a click above my base settings but this also can make small bumps more noticeable or compromise traction.
    HSC is high speed shaft events like landing a drop or square edges at speed or g-outs. Too much and these can feel very harsh, too little (with correct air pressure) and you bottom out too easily.
    My personal set up choice is air pressure for ~20% sag and overall support through the stoke then add LSC and HSC to fine tune.
    I have the same fork and use 7 or 8 clicks of LSC and 1-2 HSC
    Quote Originally Posted by jselwyn View Post
    No lock out.
    Huge thanks for the detailed response. How much do you weight?
  1. Sram Guide Ultimate vs Level Ultimate
    By bogeydog in forum Brake Time
    Last Post: 11-22-2017, 09:23 PM
  2. Ultimate Sport Mechanic VS. Ultimate Pro UltraLight
    By falcondrgn in forum Tooltime
    Last Post: 09-10-2008, 10:28 PM
  3. RS Lyric 2-Step VS RS Lyric U-Turn VS Fox 36 VAN RC2
    By ruiabreu in forum Shocks and Suspension
    Last Post: 10-22-2006, 12:34 PM
  4. Avid Ultimate vs. Ultimate Pro levers
    By Pritchett in forum SRAM
    Last Post: 03-03-2006, 01:31 PM
  5. The Ultimate of Ultimate Riding Tours...
    By bikeCOLORADO in forum Riding Passion
    Last Post: 02-19-2004, 05:29 PM
Members who have read this thread: 44
