Lockout from Recon Solo Air transferred to a Rev Solo Air possible???- Mtbr.com
    I picked up a 2013 Revelation RLT and a 2013 Recon RL with remote lock. The 100mm recon is going on a short travel hardtail and really doesn't require a lockout. I have no idea about fork internal - Would it be possible to put the lockout on the 140mm Revelation instead?
    Is there a lockout kit available after market?
    Reputation: mullen119's Avatar
    If its a Recon Gold, it may work. If its a Recon Silver, It wont work.
    You can just buy a damper as well. Pick the damper of you choice out and google it.
    For example: https://www.google.com/#q=revelation...e=off&tbm=shop
    Thanks for the response. I do work on my own bikes but I have never touched the insides of a fork or shock so I have lots to learn.
    Since I have the cable and the bar mount would this do the trick for the rest of the parts?
    Also if I have a RLT Revelation I could buy the RCT3 damper?
    The link you posted would work perfect if you wanted to keep the remote. If you want to drop the remote, you would need a different one.
    Yes, you can upgrade to the RCT3 damper if you wanted to. They are pretty expensive though, around 140$
  1. Tora SL vs Recon SL Solo Air?
    By smerdy in forum Beginner's Corner
    Last Post: 09-19-2013, 03:20 PM
  2. 2011 rockshox recon gold solo air internals into a 2008 recon 351?
    By mobile chernobyl in forum Shocks and Suspension
    Last Post: 07-08-2013, 11:59 AM
  3. Rockshox Recon Silver Solo Air
    By huffster in forum Shocks and Suspension
    Last Post: 05-18-2013, 08:24 PM
  4. '12 Marathon LR vs. '10 Recon TK Solo Air
    By wheeljack in forum Shocks and Suspension
    Last Post: 09-13-2012, 04:43 AM
  5. Recon Solo Air?
    By skankingbiker in forum Shocks and Suspension
    Last Post: 08-30-2012, 11:07 AM
