Lefty Speed Carbon - shock pump wont show air pressure- Mtbr.com
Results 1 to 3 of 3
    Hi !
    When I attach my shock pump to the Lefty´s schrader valve the air pressure isn´t displayed. It works perfectly with the rear shock, so I don´t think I should blame the pump...
    Any idea on that ?
    Thanx a billion in advance for your time !
    Jun 2003
    Try a different pump.
    Quote Originally Posted by Candyman
    Hi !
    Any idea on that ?
    Is the Lefty taking on air, but not showing the pressure? Try out a different pump. Some valves disagree with some pump heads. Check the valve core also.
    Quote Originally Posted by damion
    Things are a bit more complicated. If the Lefty´s air chambers are empty and I pump it up, the shock pump shows the correct pressure.
    When I attach the pump again some time afterwards, the pressure is not shown any longer.
    But I think I´ll anyway try a different pump - my current one is anything else than a high end version...
    Thanx for your fast reply !
