Leaky shock...Please Help!
I know this may be a stupid question..but why is my shock leaking? My Cane Creek AD-12 id newly rebuilt and it is loosing 30-40 psi overnight. It wasn't leaking right after I rebuilt it with all new seals (3 months ago). Is this happening to anyone else? An what are you doing about it?
thanks in advance
Elim,
You might have nicked a seal or didn't clean the area well enough during the re-build. Also check that everything is good and snug
A quick way of finding the problem - add more psi and throw it in your sink and watch for bubbles
thanks.
problem solved, one of the seals was out of grease and was leaking air through the compression and rebound adjusters
- You may not post replies
- You may not edit your posts
Forum Rules
