KS Remote Dropper - Lever won't return- Mtbr.com
Results 1 to 3 of 3
    May 2012
    Bought a used KS Dropper and it seems to be in great shape. The actual dropper post functions perfectly, just the remote lever doesn't seem to want to spring back into the "home" position. I tried lubing it, it is a brand new cable and housing, but nothing has worked so far. The problem is when I bump the seat down, it spring right back up because the lever doesn't spring back in time. Any ideas??
    Apr 2005
    Loosen the bolt on the remote lever a bit. It is a fine line between having it tight enough that it does not slip on the handlebar but not too tight so that it jams the lever. The only other problem I have encountered is that you can't have any tight bends in the cable housing or zip ties that are really tight. Hope this helps.
    With the cable disconnected from the post actuator, does the remote move freely?
    Have you tried leaving a bit of slack in the cable?
  1. XT brake lever won't return.
    By KRob in forum Brake Time
    Last Post: 03-01-2014, 05:50 PM
  2. Will 2014 Fox remote shock compatible with 2013 remote lever?
    By J0hnnie in forum Shocks and Suspension
    Last Post: 09-02-2013, 07:06 AM
  3. Lever or remote dropper post?
    By kneetowaist in forum All Mountain
    Last Post: 06-12-2012, 09:11 AM
  4. XT slow lever return
    By skywalker268 in forum Brake Time
    Last Post: 02-26-2012, 01:54 PM
  5. Shimano XTR Disc - Lever Does Not Return
    By harshcore in forum Brake Time
    Last Post: 03-31-2011, 12:28 PM
