• 11-23-2005
    R332
    Judgement day! NIXON or PIKE for me?
    Over the past few months I have posted here asking about various XC/all-mountain forks to replace the four year old Vanilla 125 on my 6" bike. I have finally narrowed it down to two forks and would greatly appreciate hearing some feedback, both pro and con, from owners or people who have ridden these 2006 model forks. Here are the two and what I view as their strong points.
    -NIXON SUPER INTRINSIC
    Pro: Lighter, standard QR axle (lighter and I don't need a new hub), 5mm more travel.
    -PIKE 454 U-TURN
    Pro: Maxle make for a stiffer fork, travel adjustment.
    Thanks for your help :cool:
  • 11-26-2005
    R332
    Two days, 48 views and no replies :confused: Can't someone give me some good info and steer me in the right direction?
  • 11-26-2005
    Jaybo
    The Pike is considered the hot fork these days....
    I owned a '05 Minute that really was a very good fork but tended to skip over small bumps; however, the high speed control provided by the excellent dampening is really very good. Nonetheless, Manitou seems to still be struggling with durability problems. However, I hear and read their customer services is quite good.
    My small .02,
    Jaybo
  • 11-26-2005
    telemarc
    To put it bluntly,
    All my buddies including myself have removed our Nixon's from our reign's and installed other varios forks, the Pike being the most prevalent.
  • 11-26-2005
    R332
    Originally Posted by telemarc
    To put it bluntly,
    Yikes, that isn't exactly a glowing review for the Nixon :eek: What about the Nixon were you guys so unhappy with?
  • 11-26-2005
    telemarc
    Myself, I was not entirely unhappy with mine, until I lent it to my gal and put the new pike on. Pike is way more plush and yet can handle the big drops and get me out of trouble. I could not find the sweet spot with the Nixon Platinum but instantly found it with a few small adjustments in the Pike. Pike is definitely smoother.
    Most of my riding partners hat trouble with the wind down on (I think it is the elite) that came on their reign 2 's . Travel would gradually wind down til it was at the bottom and they would have to stop and unwind it.They also could never seem to get the rebound the way they wanted it .Most of them are large guys,200 + lbs, so I don't know if this has anything to do with it.
    I did use the travel adjust a lot but have learned to live without on my pike . I can still get up all hills the same as the Nixon just a little trickier.
    Also we all had to send them in for the new dampening rods. I sent mine early as I got the first bike to come and missed little riding but some of the guys missed half the season with theirs or had to come up with other forks. Mind you my gals Fox Talus was no better as it took 2 months as well. Service in Canada sucks except for Marzocchi as they service in Vancouver.
    But like I said I thought the Nixon was O.K. till I put the Pike on.
  • 11-26-2005
    kapusta
    -PIKE 454 U-TURN
    If you don't mind building up a new wheel, then the 20mm axle alone is worth going with the pike. I used to have a `03 Z1FR with a QR, and though the fork (especially the crown) was beefier than the Pike, the Pike tracks way better, and I think that is due to the Maxle. The travel adjust is, IMO, essential for a fork this long.
    The Pike is a great fork, and very tunable for many different applications and tastes.
    I have not tried a Nixon except the one on my friend's Riegn 2, and not for that long.
  • 11-26-2005
    Brown_Teeth
    Nixon is just a bad seed!
  • 11-28-2005
    R332
    I hear you. Looks like a Pike 454 is in my future.
  • 11-28-2005
    HoJo
    One Vote for Nixon, more
    Yes I know Nixon has had some problems and as an early adopter I suffered through many of them. But that being said the new versions, are the best forks I have tried period.
    The Nixon came in many flavors last year. The one I ended up with after many problems with other versions was a fixed Air (no IT), with TPC dampening and it has been great for over 6 mons. The IT versions are nice when they work but too complex and would fail over time, the 2005 SPV version, was horrible with no small bump compliance. As I said once I tried a fixed travel Air with TPC I was in heaven. The TPC although dated is one of the best dampening systems made.
    This year they have a new Intrinsic damper. It flat out works, feels smooth and supple on the small stuff and gradually ramps up on the bigger hits to avoid bottoming out. The progressive ramp is great on a long travel fork like the Nixon.
    If you don't need travel adjustment and want a reliable smooth feeling fork try the new Nixon Super. I have had one on the my new 6.6 for a few weeks now and I'm not switching.
    HoJo
  • 11-29-2005
    R332
    HoJo
    HoJo,
    Thanks very much for the good review and explanation. I was sold on the Pike but perhaps the '05 Nixons were the dud forks and the '06 models can't be grouped in with the older ones? I don't need to have travel adjustment so the Super w/Intrinsic could work for me. The Nixon is still lacking the Maxle of the Pike but I am sure it is still plenty stiff.
    Has anyone else tried the '06 Nixon?
  • 11-29-2005
    Mr.P
    The Nixon Elite comes with TPC+ for 06. I have not tried it but the long travel crowd loved it (It originated in 03).
    I have run both TPC and SPV in Black forks and the damping to have is based on the riding style you do and what you want.
    TPC is plush, plush, plush, especially at high speed but not very efficient for out of saddle climbs. If you sit and spin, and live for the downhill, look into this damping.
    SPV has an initial firmness, then plush (if you set it that way), less butter on the downhill but very efficient for out of the saddle hammering (especially technical), eliminates brake dive and is consistent in high speed turns.
    There is no platform AND plush fork by any manufacturer right now and won't be for years to come. Excitement about X or Y fork will always bounce from product to product but it still comes down to fork characteristics and how you ride. Focus on matching the two. The great posts on this forum give a good guide in what to expect from each fork.
    Mr. P
  • 11-29-2005
    mattsavage
    I think it's too early...
    There aren't enough people out there on 06 Nixons to get a fair comparison. So far everyone is comparing 05 Pikes with 05 Nixons of various models and releases.
    I think you should hold off until YOU have a chance to compare both forks side by side on similar bikes. There are too many biased opinions, based on second and third hand information, to make an educated decision.
    That being said...
    I have test ridden both forks (extended parking lot tests and "cutting through front yard hill bombs", alley downhills...). The 05 Pike on a Iron Horse MkIII and the 06 Nixon Platinum on an Intense 6.6 Two totally different bikes, but sweet nonetheless. Being a Manitou man, I knew that the Nixon would take some time to break in before it could be considered sweet, brand new fork on a brand new bike Not a fair comparison. The Pike was super plush and feeling excellent. But then again, this was an 05 demo bike, so it has been ridden and broken in.
    Having ridden an 05 Nixon Platinum w/SPV Evolve brand new(I didn't bother to experiment w/ the IT because it's not a feature I'm interested in), I can say that the Intrinsic 06 on the Intense was much more responsive to small bumps and stutters than even the Evolve of the 05. I haven't had a chance to ride either after the break in period, but I can only imagine how excellent the Intrinsic will feel once the fork is broken in and dialed.
    Eliminating the 05 Nixon from the comparison, I think I'd take the 06 Nixon Super over the Pike. The Nixon wasn't quite as sweet as the Pike because it wasn't broken in, obviously, but based on previous Manitou experience, I feel I have a pretty good idea of how it'll feel once it is broken in. I like the fact that it is available with QR lowers, making transportation easier and less expensive. The ease of adjustability is another factor for me. I found it easier to get good settings quicker on the Nixon. I couldn't get the Pike to be as less sensitive to pedal feedback than the Nixon. The Nixons platform is perfect for trail riding for a 190 lb guy. A significant amount of bob when hammering up over a rise, but not nearly as much as the Pike. The Pike felt more like my Sherman, and the shop guy, a Rock Shox Soldier, just couldn't get it dialed better for me. Both felt excellent when spinning in the saddle. A couple two to three foot flower bed drops yielded excellent compression characteristics of the airsprung Nixon. The Pike felt more coil oriented, which is what alot of people like, but I used pretty much all the travel off a mere 3' ledge. The Nixon left me with more than an inch to spare, with only a couple clicks in on the volume adjuster.
    I tried to be as objective as possible when comparing the two forks, but maybe my opinions are still a bit biased. I didn't have time to properly learn how to setup the Pike on my own, but I'm not going to spend $500.00 to learn. I know alot about Manitou forks, I've been riding them for years. I really want to get a Pike, because it is a sweet fork, there's no denying that, but it's hard to break away when I feel Manitou makes a product that is comparable or even possibly better.
    It's up to you to decide. Either way, you can't go wrong, I think one of the main deciding factors is 20mm or QR. It would suck to want to go out of town to ride with friends, but your bike won't fit on his racks and you can't put it in the trunk, and you left your $60.00 20mm fork adapter on your other car which you girlfriend took for the day. So you stuck riding your XC hardtail or SS on a ripping 15 mile single track descent while all your buddies are smoking you on their 6 inch travel trailbikes.
    Wait until you can test ride both. Ignore the fools that give you the one line response saying Manitou sucks or Rock Shox sucks or whatever.
  • 11-29-2005
    mattsavage
    HoJo,
    I totally forgot that the 06 Elite has TPC+, which is in my opinion, the best of compression dampers. This years TPC+ is modified, over previous versions, specifically for long travel applications.
    Last year I would have taken TPC+ over any SPV fork (many people even retrofit their SPV Shermans and Minutes with TPC+) and I still may, but the Intrinsic is getting very close.
    The only thing differently I'd do with the Elite is swap the Rapid Travel Wind down with Rapid Travel II of the Shermans. Two settings, long and shorter, and two spring rates, plush and firm.
  • 11-29-2005
    Mr.P
    Matt,
    Manitou writes that TPC+ is "position sensitive" damping, but how does it behave on the trail? What is it's advantage? My vague memory of it is that it increases damping deeper in the travel, is that correct?
    What is it's advantage over TPC or SPVe?
    Thanks,
    Mr. P
  • 11-29-2005
    STS
    Thanks for the report mattsavage,
    Do you know if the intrinsic cartridge can be retrofited to 05 Nixons?
  • 11-29-2005
    R332
    It is great to see new information being added to this thread :cool:
    I agree that the best and only true way for me to pick a winner is by riding both, but due to a variety of reasons (location, work schedule, etc) this just isn't going to happen :( I have to put my faith in the feedback from the members here and hope that I am being given good advice!
    I have read about the TPC+, SPV, etc and on paper they all look great, however I can't choose a fork based on the cartridge specs.
    My gut feeling is still the Pike, however if I did get a Nixon I am thinking the Super is the way to go because it is a 1/2lb lighter, unless the coil with the TPC+ really works that much better than air. I don't want to add much or any weight vs my Vanilla 125 which is why the Pike Air U-Turn and the Nixon Super are so appealing.
  • 11-29-2005
    mattsavage
    I don't see why not. It'll probably take a new rebound assembly as well to make it complete.
    Right now, a new Volume adjuster and rebound assembly for SPVE costs around 75-100 bucks total, aftermarket, depending on the fork. So, I bet the Intrinsic would be slightly more than that.
  • 11-30-2005
    kapusta
    Whoa.., did this actually happen to you? ;^<
    Maybe others have different experiences, but I ride with friends with 20mm axles and Lefty forks, (myself included for the past year) and in the 7 years I've been riding there has never been a single time somebody could not take a bike due to not having a QR. Worse case scenario you take both wheels off and stick it in the car somewhere.
    But I guess if all the planets line up, (girlfriend has the car, AND you forgot the fork adaptor, AND you have to take your buddy's 2 seater sports car with no truckspace AND he only has fork-mount racks for the bikes, AND nobody has a cheap rack to throw on the back of the car) I guess it could happen.
  • 11-30-2005
    mattsavage
    Yeah, that's pretty much it.
    Originally Posted by Mr.P
    Matt,
    Thanks,
    Mr. P
    I believe, as the fork settles into its travel over a series of bumps, the additional piston prevents it from bottoming to hard on an additional hard hit. It's speed sensitive too. A high speed impact like that of a squared off edge like a rock or large root as you cruise down the trail, won't cause the fork to blow through its travel the way, say, a slow speed type impact like a wheelie drop off a ledge or the old parking lot bounce test would (speed in this case refers to the rate at which the fork reacts to input, not the velocity of the bike). This allows for very sensitive small bump compliance without compromising its ability to take hard hits. Normal TPC doesn't have the additional position sensitive piston to help prevent bottoming, but is every bit as sensitive to the small stuff. To further adjust compression dampening in a TPC+ fork you have to pull out the damper and fiddle with a small set screw. TPC forks are usually externally adjustable.
    SPV controls the bottoming through its (air)volume adjuster, and slow speed inputs like pedaling forces are cancelled out by the air pressure against a valve, that's why they feel kind of knotchy or unplush at the first hit, because it takes X amount of force to get that valve to open against the air pressure. The volume adjuster reduces the amount of oil that can be displaced as the fork moves through its travel, that's what prevents bottoming, and gives it a nice ramping feel at the very end of the stroke, making it feel like it has more travel than it does.
    TPC+ is very similar in effect and feel to Marzocchi's HSCV, it's a perpetual battle, determining which is better. Neither in my opinion.
  • 11-30-2005
    mattsavage
    Yes, it has.
    Three guys, two roof racks, a rocket box, and a little old Audi. All had 20mm, but one adapter for the fork mount rack. Since I was the last to be picked up, the other guy had his behind the seat and the driver wouldn't let me take the wheels off and kind of stack/strap my bike on the roof.
    It was still a fun day. But the 20mm thing was kind of a bummer at that point. I put the QR lowers back on my Sherman for the trail bike.
  • 11-30-2005
    kapusta
    What a dick..... He just wanted to be faster than you ;^>
  • 11-30-2005
    Mr.P
    I believe, as the fork settles into its travel over a series of bumps, the additional piston prevents it from bottoming to hard on an additional hard hit...
    SPV controls the bottoming through its (air)volume adjuster...
    Thanks bro, quality info.
    Mr. P
  • 11-30-2005
    MK_
    JensonUSA is selling 05 Nixon Super (fixed 145mm travel, TPC damping) for $250! You have an option of either QR or 20mm. I would say that it is a worthy experiment. I definatelly wouldn't condone the SPV Nixon, nor the IT Nixon, but the plain old TPC is excellent and 145mm of travel sounds like a ticket for your 6" frame. At $250, that's hard to beat.
    _MK
  • 11-30-2005
    hammerheadbikes
    I tried the Pike Team air and hated it
    no small bump sensitivity whatsoever
    the Nixon super tpc is a LOT smoother
    the Intrinsic sounds great and I know Hojo is digging his
  • 11-30-2005
    The Squeaky Wheel
    Charles,
    i'm surprised to hear you say that as I usually agree with you.
    I've found the Pike air to be very smooth on small bumps. I have several friends who are very good riders who love the Pike air, and they are very critical when it comes to these things.
    Not a setup or break-in issue?
  • 11-30-2005
    Oni
    My thoughts
    My '05 Nixon Platinum sans 20mm has been down three times with minimal riding on the fork. The second time I received it back from the factory, let it sit, then gave it to a friend to try and it stopped working on his 'just put the bike together' parking lot ride.
    Replaced it with the '05 Pike Team. Like, no love the Maxle feature. I find it stiffer than the Manitou and it just feels better. The springs seem a bit heavy for my 175~lbs w/ gear self as I haven't bottomed it yet. Much more confidence on nasty stuff. The fork just feels better. And I don't have to worry about sinking thru its travel on a particularly nasty section (as the Nixon did on it's second ride).
    That said, I surprised myself and really liked the ITch feature of the Manitou. I'm swapping out the old internals for the new, "Manitou ninja says it'll work" internals and IF the fork works on a regular basis, it'll be a good fork. And it's pretty danged light.
    I'm just totally turned off with the three times broken aspect of it. Customer service at Manitou was abso-frickin'-lutely awesome! Almost would buy another Manitou based on that alone. But then I remember how many issues Manitou has had, going back to their EFC line of forks…
    Oni
  • 12-01-2005
    Dougal
    My Nixon is fantastic. But it is two things
    1. Coil sprung
    2. TPC.
    I do not care for the feel of SPV at all and I much prefer the feel of coil springs over air. This makes my nixon a longer but lighter 03 firefly which most will agree is a great fork.
    If you wish to upgrade to TPC+, then the 06 compression damper should thread straight in.
    The $250 Nixon at Jenson would do the job nicely if travel adjust isn't a concern. I find the travel adjust handy for fitting my bike into a box or car. I always ride at full travel.
  • 12-01-2005
    Mr.P
    1. Coil sprung
    2. TPC.
    Hey Dougal, your website clued me into higher oil levels and how it will make TPC more progressive. Thanks for that!
    I'll bet that kind of tuning can help a longish travel Nixon.
    What is the oil level that you are running on your Nixon?
    Thanks,
    Mr. P
  • 12-01-2005
    hammerheadbikes
    I set the fork up correctly, jacked up the negative air pressure to overcome initial stiction, etc.. I wanted to like it...
    I rode it for a week, several 3 hr rides in very rocky terrain
    it just felt like a big SID, didn't move unless it was slammed into something...
  • 12-01-2005
    The Squeaky Wheel
    Wierd. Not my experience at all.
    Win some, lose some.
    It's the best air shock I've tried.
  • 12-02-2005
    Dougal
    Thanks,
    Mr. P
    I think you might have the wrong end of the stick there.
    You shouldn't use oil height to tune a TPC damper. You need enough oil to make the system work, but not enough to make it hydraulicly lock at the end of the travel. I run my forks at 1-2 inches of oil above the top compression piston. Some which I've modded for more travel I have to run the minimum 1 inch, the rest I run at 2.
    If you're concerned that your fork might be overfilled, just take the spring cap off (or let the air out) and compress it by hand. If you can push it easily to the bottomout bumpers then you're fine. If you can't then you might have to remove some oil.
    This hand compression trick is a good idea if you think you've overfilled the semi-bath lube too.
    For extra progression, you might be able to add oil to the air spring chamber (air forks only of course), but I haven't been into an air spring Nixon to check.
  • 12-02-2005
    Mr.P
    Sorry, I must not have been clear. Manitou has a stated oil height range and your website clued me into running the maximum oil level stated by Manitou for a slightly more progressive feel.
    Great info on your website. Thanks!
    Mr. P
  • 12-02-2005
    dulyebr
    Charles, What about the extra stiffness from the Pike's thru-axle, was it very noticeable over the Fox PSC chassis?
  • 12-02-2005
    Dougal
    Mr. P
    Happy to help. I've gotta get around to updating it one of these days.
    :cool:
  • 12-02-2005
    Jaybo
    I have a Revelation fork
    Only rode it once but liked it; however, I owned a SID 100 that I liked pretty well in its day. I know, how weird, but I'm easy to plase I guess. Anyway, the Revelation is not as smooth as my Pushed Vanilla but MUCH more adjustable and lighter :). The Pop Lock deal is a bit funky but I'm just learning how to use it. I don't know if I like it on my bar. Hammerhead Charles must have gotten a bad fork.
    Jaybo
  • 12-03-2005
    anden
    Sounds like unfortunate setup.
    Jacking up neg pressure makes the fork stiffer. Yes, the user's manual is wrong. And indeed lots of people seem to have got the same problem as you, not surprisingly.
    Correct: Use positive pressure to set spring rate (don't be afraid to go lower than the manual's numbers). Then, use neg pressure to set sag. Increasing neg pressure not only increases sag but also makes the fork a bit stiffer, so you may want to re-adjust positive pressure.
    Too much compression damping, either Gate or Compression, may also have contributed to the stiff feeling.
