Ibis Traction Tune- Mtbr.com
Results 1 to 24 of 24
    Mar 2019
    Ibis Traction Tune
    FINALLY! All the other bike manufacturers should follow this example. Itís called "Common Sense" and it was about time
    - Less compression?
    Yes please
    - Matching front and rear suspensions? Yes please
    - Data acquisition system to stop the guesstimations once and for all?
    Yes please
    Source: https://www.mtb-mag.com/en/ibis-trac...ne-philosophy/
    Dec 2018
    Yes it makes sense in theory, the wheel moves faster and gets out/over the obstacle as fast as possible.
    If you are heavier or faster than the mean average, this goes out the window.
    One watch of Jeff Kendall Weed's new video on the new Ibis you will understand. Ibis rep sets the bike up as he thinks is "optimal", JKW does run after run..... every run he firms up compression and slows rebound to the exact opposite of their "optimal" setting. It made me laugh because Jeff is extremely positive/supportive of all his sponsors (almost too much sometimes) but I actually liked this breath of fresh air where he went against the grain of the hand that feeds him.
    TLDR: Great in Theory, may not be your cup of tea.
    Reputation: minimusprime's Avatar
    I have the same opinion of yeti's tune calculator. I have no idea how at 180lbs I could get away running the grip 2 fox 36 and x2 completely wide open on compression and a solid 3-4 clicks faster rebound then I find controllable.
    Aug 2013
    You mean they measured what was happening and adjusted accordingly? Then what the **** have they been doing for the last 35 years? Just winging it?
    Quote Originally Posted by brash View Post
    I had a similar impression. This seems to be tuned for folks who don't push their bikes all that hard and want "plushness" above everything else. Folks who ride hard and put large impacts into their bikes are going to have a bad day with this tune.
    Running a light compression tune means you're depending almost entirely on the air spring to prevent bottoming, which means you'll need to run a pretty progressive spring setup if you want to maintain small & medium size bump compliance. Which means that sucker is going to kick back hard on the rebound stroke, and with the super light rebound tune they're advocating there's no way to absorb that energy so it'll bounce back hard and buck you right off the bike. There's a reason that Jeff Kendall Weed runs a lot more compression & rebound damping than the Ibis recommendations, he doesn't want to die from getting bounced around and bucked off the bike.
    We went through this already with elastomer suspension back in the day, I don't know why we're trying to repeat the same mistake with modern suspension parts.
    Aug 2013
    Quote Originally Posted by aerius View Post
    Some industry people seem to think that compression damping is only to improve pedalling performance.
    Got clarification from Ibis. They are keeping and recommending normal LSC and opening up the HSC and Rebound.
    Here's what I ride my HD4 at:
    2018 FOX 36 RC2 160:
    • 85-90PSI
    • -18 out of 22 HSC at the lighter end of the scale.
    • -15 out of 25 LSC. middle of the range.
    • Rebound is slower -5 from fully closed.
    Fox X2 at 240PSI and Ibis recommended settings. Maybe 1 click less HSC.
    Closer look at things, as a heavier aggressive rider I will probably get along fine with the Compression tune. Still have the range I need in the adjusters.
    Still unsure about the Rebound as I'm only -5 from fully closed.
    Jul 2017
    First im a novice pretty much.... so my experience might means p#$s all.
    i agree w the ibis approach to tuning, but could this just be some creative marketing to promote things everyone already does. Hard to believe no manufacturers have tested their bikeís suspensions.
    Reputation: Vespasianus's Avatar
    I think this is just a larger sign that people have no idea what they are doing with suspension set up - which has nothing to do with the complexity of process but rather the stupidity of the general population.
    It is the Right of the People to Alter or to Abolish It.
    Quote Originally Posted by Vespasianus View Post
    The other part of the problem is that most suspension is simply untunable. A RS Pike which is probably the most popular fork on the market has a wonky damper setup that still hasn't been fixed after 3 generations, and combined with its air spring curve it makes the fork damn near impossible to setup correctly for many people. You end up using all kinds of wonky compromise solutions & setups to try and make it work and you can even open up the damper to rework the internals and use aftermarket parts. But even after all that it barely works as well as stock Mattoc with half an hour of knob twiddling to get things in the ballpark.
    The market is filled with all kinds of dysfunctional suspension designs and all sorts of kludges, hack fixes, and mis-information to try and get around the suckage, it's no wonder the average person gets confused as hell. If every fork just worked like a Manitou, suspension setup would be a hell of a lot easier.
    Apr 2018
    this. it's marketing.
    Fox offers OEMs different shim stack configs & base valves that they can pick out of a catalog. I doubt anyone is outsourcing for custom pistons, etc. "custom" is a very relative term, and at the end of the day, they still have to target the average rider of average weight on the average trail in average conditions. this is why i hate the marketing aspect of it, it's just setting unrealistic expectations and offering inflated value. shops like Vorsprung, Avalanche, and Shockcraft are your friend and offer real value if you have the time, patience, and funds.
    Mar 2019
    But itís a move in the right direction instead of sticking the same tune to every size frame etc ...
    Custom tuned is better but a lot of people think itís not for them (I'm not racing so bla-bla-bla) ... or donít even know about it!
    Sep 2019
    Quote Originally Posted by FactoryMatt View Post
    So much yes to everything you just said.
    Mar 2019
    Data acquisition is very far from marketing! Even the tuners donít use them (or a very small percentage). Thatís how it should really be done.
    No wonder the top DH guys are relying more and more on it ... because itís impossible or very time consuming to guess what to change when you donít know whatís going on underneath you.
    I dislike the marketing speeches as much as the next guy and donít really want to comment on the light tune or whatever ... what I'm seeing here, is a very good starting point for reflection about what should be done to improve the not so great out-of-the-box suspensions.
    Dec 2018
    Quote Originally Posted by digev View Post
    What the WC riders are doing is setting the bike up to be as fast as possible, this would be totally different to a "comfort" or a setup that any mere mortal will use. These race setups would be so stiff and un-rideable at anything under 10/10ths race pace.
    Your average joe blow trail hacker needs something they feel comfortable on.
    I'm not talking comfort as in soft cushy suspension, rather confidence comfy. The WC guys are on the "kill deathstar 5000" tunes.
    Apr 2018
    they say "we were looking for wheel movement speeds of X"
    ok. why? yea, the data helps you get there, but why that number? and again, the wheel speeds are only relevant to a very specific set of circumstances.
    it's marketing because more likely than not that the numbers don't work for you. there are just so many variables. it's better than nothing, but i'd rather they just put the cost into using better factories or better paint or more paint options or whatever. and, no amount of "custom" (picking stuff out of a catalog) tuning will help the inherent limitations of a factory design. examples: X2 midvalve, Charger 2 midvalve, Grip 2 negative spring.
    Attached Thumbnails Attached Thumbnails Ibis Traction Tune-30821621_2045917735647068_2918488629673196449_o.jpg
    This place needs an enema
    Reputation: mikesee's Avatar
    Aug 2003
    It's almost, kinda, like we're all different in our preferences, experiences, expectations, and likes.
    Apr 2018
    Quote Originally Posted by mikesee View Post
    it's almost, kinda, like we're all different in our speed and ability.
    fify
    Jul 2017
    Lots of people take advantage of clever marketing tactics. This isnt the first nor the last.
    Reputation: cchough's Avatar
    That's not marketing, that's just reality. MOST people who buy $8k enduro/trail bikes aren't wringing them out on pro-level enduro courses. Ibis could tune their bikes to make JKW happy but he's an outlier, an extreme edge case. Folks like JKW (and you apparently) want a different feel - fortunately, you and JKW know how to tune your suspension accordingly. If Ibis, on the other hand, tuned for JKW, the dentists (I'm not a dentist but I ride like one) with no idea what those colorful knobs do would be screwed.
    Sycip Unleaded 650B
    Sycip Ti Gravel
    Pivot Mach 5.5
    Ride Fast Take Chances :)
    Reputation: alexbn921's Avatar
    A light tune is good. The range should be perfect for 90% of riders, even big aggressive ones.
    The "Traction Tune" moniker is marketing.
    Making shit harder than it needs to be isn't awesome, it's just...harder.
    Mar 2019
    Quote Originally Posted by alexbn921 View Post
    Sums it up pretty well!
    Aug 2003
    fify
    Touche.
    Desire has more to do with it than speed and ability.
    Reputation: Dougal's Avatar
    Data acquisition can get out of hand really quickly. Generating massive amounts of data that if sorted or analysed wrong is completely useless.
    The massive limitation is in only measuring the outside of the assembled box.
    It's the most use when you've got riders who can punish gear a lot more than the engineers can (i.e. racers) but those riders tend to suck at giving feedback on exactly what is doing what.
    But then you need to link in your multi-channel data stream with a trail map location and video of the lines taken.
    Suddenly it's not a bike with a data logger attached any more. It's a heavy data logger with wheels!
    Owner of www.shockcraft.co.nz, Mech Engineer, Tuner, Manitou, Motorex, Vorsprung EPTC, SKF, Enduro
    www.dougal.co.nz
  1. When is more traction, too much traction?
    By singletrackmack in forum General Discussion
    Last Post: 05-15-2017, 05:21 AM
  2. Tune Kom-Vorr vs Tune Concorde
    By TheGenTwo in forum Weight Weenies
    Last Post: 12-22-2011, 02:41 PM
  3. Monarch RT3 - High Tune vs H3 Tune?
    By madtrix in forum Shocks and Suspension
    Last Post: 07-26-2011, 06:42 PM
  4. Mid tune or high tune??
    By eddievettelt1 in forum All Mountain
    Last Post: 05-17-2011, 11:02 PM
  5. Replies: 3
    Last Post: 04-13-2011, 09:49 AM
Members who have read this thread: 179
