hows the shocks on this bike compare to the RS Dart3- Mtbr.com
Results 1 to 15 of 15
    Reputation: louisssss's Avatar
    http://www.specialized.com/us/en/bc/...=40347&eid=103
    SR Suntour SF9-XCM-V2, 100mm, 1pc. alloy lower, 30mm Hi-Ten stanchions, coil/mcu spring w/ preload adj., spring seals
    how are those shocks compared the Rock Shox Dart 3?
    Former Bike Wrench
    The Dart has compression and rebound damping along with a lock out. While the legs are a skinnier 28mm, at least they are cromoly vs hi-ten on the Suntour fork.
    The Dart 3 is a better fork...even dare I say substantially better.
    Quote Originally Posted by mtnbiker72
    really?!?! my LBS told me that the shocks on that P.1 All Mountain are more heavy duty than the dart 3's...
    RH SL Pro
    Former Bike Wrench
    Quote Originally Posted by louisssss
    I'm sure they weren't trying to sell you that particular bike
    Your question was how it compares to the Dart3 and the Dart3 is better. If you want the more heavy duty fork, then this one can't be beat
    They are right about one thing...they are more heavy
    so the shocks on the supposed "made for jumping" P.1 AM are worse than the XC Rockhoppers?
    lol damn
    RH SL Pro
    whats so good about this fork?
    RH SL Pro
    Um, Rigids are, by definition, more heavy duty than any suspension fork. Arguably, of course.
    lol damn
    The Suntour is probably a stronger and definitely a stiffer fork, both of which are good for jumping. You don't need a very advanced damping system for jumping, nor do you need lockout.
    Stupid DB upgrade.
    Stupid DB upgrade.
    Stupid DB upgrade.
    Stupid DB upgrade.
    Stupid DB upgrade.
    Quote Originally Posted by bad mechanic
    ic, so u think that suntour model in the original post will be able to withstand more damange?
    for example: hitting curbs, hopping off NYC curbs, hitting potholes
    RH SL Pro
    The wheel will give out before either the Suntour or the Rock Shox. The Suntour would most likely take the rigors of dirt jumping significantly better than the Dart. If you're looking for a XC or AM fork, though, you're better off saving your money and buying a fork with a proper damping system.
