How often do you change your fork seals?- Mtbr.com
Results 1 to 8 of 8
    Is it necessary to change the seals everytime I change the oil, or if the seals are in good shape, can I just change the oil and reassemble?
    If the seals are good just change the oil and let it roll.
    Yeah, I only change seals if there's a leak, or if I still feel stiction after a thorough interior clean and grease/oil replacement (regrease your seals).
    Oct 2012
    Change seals only if there is an oil leak. Otherwise just clean the fork and old oil, grease the seals and put new oil. Good luck, and always inspect your seals.
    Guest
    I've got a 10+ year Duke that's on the original everything but oil. I generally assume everything is okay until it wears our or I break it. When you think about how long seals last in a motorcycle fork, not sure why a bike would wear them out any faster.
    What kind of grease is everyone using? The seals were in great condition, so I just cleaned off the little bit of gunk that had built up inside of them. I've read slick honey is the way to go, but I didn't have any, so i just put a thin layer of Park's Poly Lube on them. Fork feels smooth. I can always order the slick honey and then redo if it's necessary.
    The oil in the lowers was pretty dirty. Other than that everything checked out ok.
    Guest
    I don't grease the seals on my Fox Fork. I use the Fox Float and renew it when it starts sticking (every 9 months to a year. On my older RS Duke, I use triflow currently but I'm convinced that I can use Fox Float on that fork too.
    Reputation: Gman086's Avatar
    Quote Originally Posted by grandegrande View Post
    Slick Honey. Other greases may or may not be compatible with the splash oil, SH is so that's what I always use. Pack some just under the lip in the cavity keeps the fork nice and smooth.
    Have FUN!
    G MAN
    "There's two shuttles, one to the top and one to the hospital" I LOVE this place!!!
  1. When to change fox seals?
    By I♡bikes1999 in forum Shocks and Suspension
    Last Post: 04-17-2014, 12:32 AM
  2. Elixir 5 pad change damaged seals?
    By danguskhan in forum Brake Time
    Last Post: 04-15-2013, 11:01 PM
  3. How often to change seals on Fox fork?
    By alanmack in forum Shocks and Suspension
    Last Post: 04-16-2012, 05:33 PM
  4. New seals every oil change? FIT damper service?
    By Boylerules in forum Shocks and Suspension
    Last Post: 09-13-2011, 05:52 AM
  5. Let out air in TALAS to change oil/seals?
    By bitewerks in forum Shocks and Suspension
    Last Post: 04-13-2011, 01:28 PM
