How to make Fox bushings better- Mtbr.com
Results 1 to 1 of 1
    Feb 2010
    Fox five piece bushings are quite nice. Unless the eyelet in the shock is too small. Then the fit is very tight and the pin does not want to rotate inside the bushings.
    I took a small strip of sanding paper, put it around the bushings and rotated them back and forth. End result is a very nice fit and smooth movement of the shock.
    Be careful not do remove too much material. Check the fit often. It is useful to install only one bushing at time for checking. Then it is easy to press it out with socket when you need to sand more.
    Attached Thumbnails Attached Thumbnails How to make Fox bushings better-bearingsand.jpg
  1. Offset bushings kits, DU bushings, and shock bolts questions
    By turky lurkey in forum Shocks and Suspension
    Last Post: 06-15-2015, 07:35 AM
  2. Replies: 2
    Last Post: 01-10-2014, 01:56 PM
  3. When did Cannondale first make & last make the Super V?
    By TheeSuperUberV in forum Cannondale
    Last Post: 08-12-2013, 09:03 PM
  4. Does anyone make a cross make matchmaker?
    By Andrewfuzzy in forum Brake Time
    Last Post: 06-18-2012, 11:39 AM
  5. DU bushings - where to buy
    By freeriderB in forum Downhill - Freeride
    Last Post: 01-16-2012, 09:46 AM
