How to change '08 Fox DHX 3.0 coil spring- Mtbr.com
Results 1 to 13 of 13
    Hi everyone,
    I want to replace my DHX 3.0 coil spring into the harder one by myself.
    I want to know what is the right tools for the job and the step-by-step guide to replace the coil spring.
    I did check the Fox website and it only shows the manual for forks.
    I also search mtbr and didn't find anything about replacing coil shock, so really sorry if this thread is repost.
    FYI my bike is stock '08 Giant Reign X-1 and I live in Indonesia so don't expect nearest PUSH or even Authorized Fox Dealer to help.
    Calm Like a Bomb
    Reputation: pipes10's Avatar
    no tools required.....loosen the preload ring, lift spring up, remove the spring retainer, then slide the spring off
    it's all in the manual: go to rear shocks, dhx, dhx 3.0, then click on changing springs
    http://www.foxracingshox.com/fox_tec...008_om_eng.htm
    '17 Hatchet Carbon
    '17 Troy Carbon
    '16 Django Carbon
    '16 Wilson
    '16 Farley 5
    https://www.instagram.com/jayparrington/
    Engineer The Future Now!
    Reputation: ver-T's Avatar
    Quote Originally Posted by pipes10
    He may run into an issue w/ the lower reducers. There is another thread on this subject in the Giant sub-forum here: http://forums.mtbr.com/showthread.php?t=475255
    holy...
    Calm Like a Bomb
    Quote Originally Posted by ver-T
    true, but that's why i posted the manual and where to look in the manual....that info is in there as well
    '17 Hatchet Carbon
    '17 Troy Carbon
    '16 Django Carbon
    '16 Wilson
    '16 Farley 5
    Quote Originally Posted by Gembong
    Pipes10: Don't get me wrong, you gave good advice.
    Gembong: Please post up when you do the spring swap and let us know if you were able to get the reducers out by hand or if you needed a vise or bolt extactor. Some have been able and some have not. I haven;t tried on mine but I'm kinda curious now.
    holy...
    Calm Like a Bomb
    no worries at all...i took no offense and hope i didn't offend as it wasn't my intention
    '17 Hatchet Carbon
    '17 Troy Carbon
    '16 Django Carbon
    '16 Wilson
    '16 Farley 5
    I actually changed the spring on my DHX 3 today. Its on a 2008 Reign X1 aswell. I couldn't get the reducer out by hands so I went to a bike shop and they simply used a vise to get it out. Very simple in fact and I'll do it myself if I ever need to do it again.
    By the way, I weight 145 pounds geared and I quite happy to have switched from a 450X2.37 to a 400X 2.45 spring. The bike gained in plushness and track better than before.
    Ha! Looks like I'll need the vise. Thanks a lot fellas, I'll try to fix this and I'll report the result ASAP. Thanks also for all the links.
    OK, it's done. Pipes10, you were right about it, but I have to use the special tool for loosening the preload ring, it called hook wrench, otherwise you could damage the preload ring.
    VerT & nightnerd, both of you were right too about the vise. Luckily I found one on my father's garage, and yes I do use the vise, it's a lot easier. Just make sure to put something proper to prevent damage from the vise. FunniIly I use folded newspaper, and it works.
    Now my Reign X-1 should be ride better, nearest hill here I come! Thanks a lot, fellas!
    Calm Like a Bomb
    if the preload ring is too tight to turn by hand u can firmly grasp the spring and turn it....that will loosen the preload ring enough so u can turn it by hand...no need for a special tool
    '17 Hatchet Carbon
    '17 Troy Carbon
    '16 Django Carbon
    '16 Wilson
    '16 Farley 5
    Thanks for the tips!
    Just did this on a DHX 5. Used a center punch, a vise, and some finesse to get the reducer out/in. Kind of a pain in the ass but worked like a charm in the end. Now I just need to get out and ride with this new Ti coil...
    Reputation: JOSBRO's Avatar
    Just swapped the lower reducer on my '07 DHX 4 air. Found this thread when I got stuck. No vice on hand, but used a socket and a 16 oz finish hammer- worked.
    I wasn't biking while I was typing this... I call that wasted time!!!
