Help with new fork - let oil leak out of the compression adjust.- Mtbr.com
Results 1 to 5 of 5
    Jun 2019
    I'm an idiot. Bought a new fox rhythm 32 with the remote lockout mechanism and was fiddling with testing how turning I need to get it to lock out, but somehow ended up loosening it to the point where oil started pooling at the top. Ended up figuring out the mechanism and tightening it but not before losing a good amount of oil.
    Am I screwed? Can I just add oil directly to the compression pin hole? Or do I need to completely disassemble the lowers?
    Thanks in advance.
    You might be ok, the dampers are slightly overfilled from new and "self bleed" with use. If you left it leaking out until it stopped you might have a slight issue. The way to check is put the lockout on and if its solid you should be fine
    www.thesuspensionlab.nz
    Servicing in Rotorua, NZ/Vorsprung Elite Tuning Centre/DVO service centre/Insta @thesuspensionlab
    Jun 2019
    Quote Originally Posted by JohnnyC7 View Post
    Thanks - unfortunately there was quite a bit that leaked out. The lockout doesn't seem to be working with the pin turned all the way to the right (although it didn't seem like it was working before either). Looks like I'm buying the tools to disassemble the damper and fill it up.
    Magically Delicious
    Reputation: Cleared2land's Avatar
    Try warranty repair?
    A bad day of cycling is better than a good day at work
    Work Truck - Dassault Falcon 7X
    Jun 2019
    Quote Originally Posted by Cleared2land View Post
    Nah, it was my fault. Besides it would probably cost more to send it back than to just refresh the damper fluid.
  1. Replies: 0
    Last Post: 06-29-2013, 05:54 AM
  2. oil leaking out of FIT cartride lock out/compression ass'
    By paddy73 in forum Shocks and Suspension
    Last Post: 09-25-2012, 06:25 AM
  3. Oil leak or normal? New Fox DHX 4 leaving oil on the shaft
    By scocra in forum Shocks and Suspension
    Last Post: 07-02-2012, 10:44 AM
  4. Minor oil 'leak' after changing fork's oil
    By MrR in forum Shocks and Suspension
    Last Post: 08-15-2011, 04:28 PM
  5. small oil leak after oil change on Z1 Light
    By nybike1971 in forum Turner
    Last Post: 06-12-2007, 07:03 PM
Members who have read this thread: 29
