Help needed for Bluto RCT3 damper assembly- Mtbr.com
Results 1 to 1 of 1
    Feb 2019
    I just completed the rebuild on a Bluto RCT3 assembly, following SRAMís installation guide which overall worked out pretty well. I was in the process of repositioning the lowers closer to the uppers (Full compression) to install the two bolts into the air & damper shafts when a small 1/8th x ~4Ē long shaft popped out of the damper assembly and I lost a lit of oil from the uppers. And it was all going smoothly until then, having completely rebuild the rest of the unit. Ugh. So now Iíve completed the rest of the assembly, but the low-speed compression 4-prong knob that attaches to the ďpoppedĒ shaft via a small flat head screw is in question. I can re-insert the shaft, but I I feel Iím missing something at this point, probably flew off in my shop and is gone forever. The lever for open/mid/close is also not held down securely either. Iíve looked for diagrams and such to provide some insight on this, but am stuck. Iím hoping someone here can provide insight on how to correct this, and thank you in advance!
    Here are some pictures, where Iíve lifted the shaft out of the damper assembly slightly to show what is no longer held in place by the mystery object.
    Attached Thumbnails Attached Thumbnails Help needed for Bluto RCT3 damper assembly-792a67d7-2cb5-4d92-bb80-f782af7460ec.jpg
    Help needed for Bluto RCT3 damper assembly-9ab74dbc-c436-4781-b850-4a8fe2376f96.jpg
  1. Replies: 5
    Last Post: 11-19-2016, 06:48 PM
  2. Bluto RCT3 upgrade Kit?
    By aredemann in forum Fat bikes
    Last Post: 11-18-2016, 08:50 AM
  3. Need Fat bike advise Bluto or no Bluto
    By brianbmw in forum Fat bikes
    Last Post: 07-12-2016, 03:23 PM
  4. Bluto rct3
    By ShredMaster in forum Fat bikes
    Last Post: 06-28-2016, 09:51 AM
  5. Bluto parts compatibility / RCT3 damper
    By matto6 in forum Fat bikes
    Last Post: 01-09-2016, 01:41 PM
Members who have read this thread: 11
