Help me understand DPX2 models- Mtbr.com
Results 1 to 8 of 8
    Appalachian Singletrack'n
    Reputation: Endomaniac's Avatar
    I'm having some difficulty understanding the difference between the versions of the Fox DPX2. I'm looking at a couple of bikes that come with this shock, some of them have the ability to upgrade the shock when you purchase the bike.
    DPX2 Factory, I understand this one.
    Float DPX2 EVOL Performance Elite , I think this is the same as the factory without the kashima coating at least this is the case for forks and I'm assuming shocks would be the same. Could someone verify my assumption.
    DPX2 Evol Performance, I cant find any info on this one as to what is does/has different. I'm assuming it looses some adjustments but its unclear. Could someone explain what this shock lacks that the others have.
    Thanks for the help.
    You’re right about the performance elite model.
    For the performance model (non-elite) you lose the open-mode adjustability. This is the 10 click compression adjustment seen in the center of the firm/medium/open dial on the factory and PE units.
    Reputation: brentos's Avatar
    I'm curious about this as well. Aside from the fact that the Performance is not adjustable for low speed compression damping (open mode), does it control oil flow in the same manner, but simply in with out the adjustment?
    Ride On!
    Reputation: NorthSideOf50's Avatar
    Nov 2013
    Reputation: MSU Alum's Avatar
    Oops....
    Quote Originally Posted by incubus View Post
    I'm bumping this. As more bikes come with the Performance (non-elite) DPX2, incubus' answer was pretty helpful.
    Jan 2009
    I just got a bike with the Performance, it has a simple screw screwed in where the LSC adjust was on the Performance Elite. Makes me wonder... is it just a case of disabling a feature for OEM equipment, e.g. so manufacturers can differentiate build levels. Wonder if one could "unlock" the LSC.
    Quote Originally Posted by uknathank View Post
    No you can't. There's no needle under there, you would need to buy a whole base valve
    www.thesuspensionlab.nz
    Servicing in Rotorua, NZ/Vorsprung Elite Tuning Centre/DVO service centre/Insta @thesuspensionlab
  1. New Fox DpX2 shock
    By Dagonger in forum Shocks and Suspension
    Last Post: 06-22-2019, 03:51 AM
  2. Fox Float DPX2
    By junior77 in forum Yeti
    Last Post: 06-19-2019, 12:44 PM
  3. Ripley LS shock: Fox DPX2
    By cgnreno in forum Ibis
    Last Post: 10-03-2018, 06:11 AM
  4. DPX2 help
    By Headoc in forum Shocks and Suspension
    Last Post: 11-21-2017, 04:35 AM
  5. Models that I dont' see. Future models?
    By markchang in forum Nicolai
    Last Post: 06-04-2011, 01:06 AM
Members who have read this thread: 66
