help Lyrik 2020- Mtbr.com
Results 1 to 9 of 9
Thread: help Lyrik 2020
    Mar 2012
    help Lyrik 2020
    Hi all,
    I just bought*a Lyrik 2020 150mm and it have 4 HSC click. Is it right? I read that it should have 5 clicks. Anyone could check?
    I see that it didn't returns automatically to it's full travel. Is it normal?*I send you some pics.
    Thanks a lot
    Nov 2015
    Yes, you have 5 HSC adjustments
    This means there are 4 clicks
    If there were 5 clicks, youd have 6 HSC adjustments
    Mar 2012
    Quote Originally Posted by bmwzimmer View Post
    I don't understand, how I can set up 5 adjustments with 4 clicks?
    One click of adjustment is the point the adjuster is in at the time. Fully open the adjuster, thats position 1, then you have a further 4 positions or clicks of adjustment.
    Reputation: mfa81's Avatar
    Quote Originally Posted by mastralbe View Post
    just like if you want to split something in 5 parts you make 4 cuts, kinda the same idea
    Reputation: austink26's Avatar
    Jun 2019
    1 | 2 | 3 | 4 | 5
    The bars are the clicks.
    The click itself is not the adjustment you're making. Its the spot the knobs rests at that is the adjustment.
    Mar 2012
    oh Perfect, now I understand. Thanks
    About the other problem, anyone know if is it normal?
    Reputation: rockman's Avatar
    hmmm, I've always left the knob on the click itself. Who knew?
  1. 2020 Orbea Rallon vs 2020 Santa Cruz Hightower
    By kzlucas in forum 29er Bikes
    Last Post: 10-11-2019, 07:31 AM
  2. 2020 Hightower 2 vs 2020 Tallboy 4
    By Doug in forum Santa Cruz
    Last Post: 09-25-2019, 06:51 PM
  3. 2020 Lyrik Ultimate not fully extending
    By Apolonios in forum Shocks and Suspension
    Last Post: 08-11-2019, 05:52 AM
  4. 2020 LYRIK C2 29" 160mm, Which air shaft for 150mm ?
    By TraxFactory in forum Shocks and Suspension
    Last Post: 07-15-2019, 10:23 PM
  5. 2020 Lyrik Select+ LSC?
    By ribbs76 in forum Shocks and Suspension
    Last Post: 07-06-2019, 05:56 PM
Members who have read this thread: 62
