help identifying Marz fork for rebuild- Mtbr.com
Results 1 to 6 of 6
    Oct 2018
    i need to rebuild this and im not quite sure what parts to look for.
    it was on a friends 09 Transition DirtBag but im not sure they are the stock forks. there is a RC2 sticker on the crown but i found a few different RC2's online.
    if anyone can help me with a year and model for parts that would be great.
    cheers
    Attached Thumbnails Attached Thumbnails help identifying Marz fork for rebuild-received_505890546808538.jpg
    SS Pusher Man
    Reputation: mtnbikej's Avatar
    Sep 2001
    2007/2008 66 rc2
    We had one on the front of our tandem.
    Seals are all you are gonna be able to find when it comes to parts, but even they are getting hard to find.
    Bicycles donít have motors or batteries.:nono:
    Ebikes are not bicycles :nono:
    Oct 2018
    Quote Originally Posted by mtnbikej View Post
    2007/2008 66 rc2
    thanks
    all im seeing that appears to be the same is the 66 RC2x
    https://www.marzocchi.com/support/fo...7-86&idS=15745
    SS Pusher Man
    Sep 2001
    Quote Originally Posted by Special Eye View Post
    thanks
    Then there you go....you found what you needed.
    I was wrong....the 2007+ 66 RC3 bumped the stanchion size up. Also got rid of the pinch bolts on the dropouts.
    B A N N E D
    Should be a pretty straightforward rebuild. Very similar to the 55's I've rebuild in the past.
    As stated above '06 had the smaller 35mm stanchions so you'll have the same seals as the newer 55's
    Stock oil is Golden Spectro 125/150 (7.5W)
    You'll want to lather up the seals with slickoleum & fill the gap between the dust & oil seals with it as well, a little messy on the 1st few rides but keeps it running smoother longer.
    Only issues I ever had with my 55's is the RC3 cart would want to spin when I would try and torque down the bottom foot nut. I've dealt with it a 2 different ways. 1st was to pressurize that leg PRIOR TO ADDING OIL with the little air valve on top if yours has one. That should put enough force on the cart to keep it from spinning. After its set remove pressure & fill. Alternatively if you're VERY CAREFUL you can find an allen head bolt to keep the hex rod from spinning and torque the foot nut while holding that hex rod in place. But don't put much pressure on that rod,it's soft & you don't want to break it.
    Aside from that don't run any air pressure in these after they are rebuilt if you can handle it, if you over pressurize & try and remove psi oil will get shot out of the air adapter. Quite a bit of it lol.
    83 Ritchey Everest
    95 Bianchi Mega Tube ti
    2015 Kona Operator Supreme
    2015 Kona Process 153
    2019 Kona Process 153 CR 29
  1. Replies: 0
    Last Post: 09-01-2015, 07:27 AM
  2. Marz Z150 FR rebuild help
    By buddiesconfusion in forum Shocks and Suspension
    Last Post: 12-20-2014, 11:47 PM
  3. Marz Z150 freeride rebuild help
    Last Post: 11-02-2014, 04:16 PM
  4. Help identifying a marzocchi fork
    By carspidey in forum Beginner's Corner
    Last Post: 09-23-2011, 04:20 AM
  5. '03 Marz Z1 FR SL rebuild/service help
    By eauxgod in forum Shocks and Suspension
    Last Post: 09-08-2006, 08:59 AM
Members who have read this thread: 23
