HELP how to change oil in vanilla fork- Mtbr.com
    Mar 2006
    Bonking ... not feelin' well HELP how to change oil in vanilla fork
    I know there has to be a web page with simple instructions on how to change oil in a fox vanilla fork. Unfortunatey I can't find it. I would really appericiate a link to a good how to site. Thanks!
    don't sweat the petty things, and pet the sweaty things
    enjoying the kool-aid
    Reputation: Chewieez's Avatar
    Mar 2006
    thanks!
    Reputation: Astroguy's Avatar
    Those directions are correct. You'll have to cut a notch in the bottom, I did it with a dremel tool. Be careful with the 26mm socket on the top caps too, the bolt pattern is shallow and the aluminum is soft, so it's easy for the socket to slip off and blemish the material. You'll see what I mean when you start.
