freeride/all mountain shock?- Mtbr.com
Results 1 to 11 of 11
    I was wondering if i could get some opinions on a good freeride/all mountain shock that doesnt cost an arm and a leg. thanks
    I CAN ALWAYS GO BIGGER
    Reputation: RYAN E's Avatar
    Get a DHX or DHX coil depending on the bike.Pro Pedal is a great feature that comes with both.DHX coil is around $400 and I dont know the price on the air
    Jun 2003
    What is an arm and a leg?
    YOu get what you pay for.
    no more than 400
    Jun 2003
    More info.
    What frame, shock length and stroke.
    For 400, you can do a lot.
    Find a used Fox Vanilla RC for cheap and have it rebuilt and re-valved for YOU werks style at push. www.pushindustries.com
    i was thinking of doing that exact thing, i even found one on ebay that has already been "pushed" for very close to my weight. it is going on a diamondback xts 3. it came stock with a 6.5" rockshox deluxe(crap). anyone think a 7.875" fox anything(float or vanilla) will fit? and can i just compress the shock a bit apon mounting? please help...thanks
    MattSavage
    Reputation: mattsavage's Avatar
    Sep 2003
    Quote Originally Posted by adens13
    No, that won't work. It'll screw everything up, geometry, leverage ratios, your rear tire will probably hit the seat tube, possibly crack your frame from increased leverage. Don't even entertain the thought.
    Get a Manitou Swinger 3way coil. You can get them for under 300 new and will blow away a Fox. Or even an old Fox Vanilla will be better than the RockShox.
    Stick with correct i2i and stroke lengths...
    "I wrote a hit play! What have you ever done?!"
    Have Ashtray, Will Travel....
    i figured that might be the case, a manitou swinger 3-way is 6.5" i2i? also, do they make the vanilla in 6.5? thanks for the advice
    Reputation: LyNx's Avatar
    You can pretty much find any shock you want in varying iui lengths, just check the manufacturers site if you're unsure they list the different lengths available.
    Quote Originally Posted by Harold
    You're doing mtbr wrong, you're supposed to get increasingly offended by the implications that you're doing ANYTHING wrong.
    MattSavage
    Sep 2003
    here, check this out...
    http://www.blueskycycling.com/view_product.php?pid=1433
    http://aebike.com/page.cfm?action=de...=30&SKU=RS5004
    The swinger might not include hardware or a spring, so it'll come out about 50 bucks more, but worth it!
    thanks
