Fox Vanilla Springs??/- Mtbr.com
Results 1 to 3 of 3
    Mar 2006
    where can I purchase extra springs for my Fox Vanilla fork???
    any help would be appreciated.
    i think i need a heavier spring as i am about 185 lbs...right??
    Quote Originally Posted by COWTIPPER
    Check the amount of sag to see whether or not you need a different spring. (Bear in mind that the sag may be adjusted somewhat by use of the preload knob.) Springs may be purchased from Fox. I've looked around for other sources, but have never found any.
    3 "fiddy" for short
    Reputation: be350ka's Avatar
    Dec 2004
    We weigh about the same and, yes, I found that I did indeed need to replace the stock spring with a heavier one. I was able to get the proper sag from my stock spring but I had to use ungodly amounts of preload. Go here and you can get them for 25 bucks.
