Fox RP23 Play at start of stroke.- Mtbr.com
Results 1 to 2 of 2
    Reputation: ir12daveor's Avatar
    I have a 2008 RP23 on an intense 5.5. The shock has recently been serviced but after my last few rides it seems to have developed a soft spot in the beginning of the stroke. If I push down on the saddle there is no resistance to the first 0.5cm of movement in the shock. After this it seems to work fairly ok. The shock appears to be holding air fine,
    Anyone any ideas?
    Cheers.
    Hey
    saw your post my partner experienced a similar problem with an rp3 on her ASR this was resolved with the replacement of a glide ring undertaken by a specialist shock serice agent TF Tuned. issue sounds identical do you experience a slightly knocking also
