Fox Roller Bearing Issues- Mtbr.com
Results 1 to 21 of 21
    Reputation: jeremy3220's Avatar
    Jul 2017
    I can't seem to keep these from making clicking noises. First was on an X2 on an enduro bike. The bike shop tried once to regrease it but that didn't work so I ended up replacing it with the IGUS bushings. Now on my new Tallboy (DPS) I'm having the same issue (possibly from bottoming out the shock). I'd like to be able to use a bearing since it's a short travel bike and will probably make a noticeable difference. I've had zero luck but no one else seems to be having issues. Anyone else have this issue or have any insight on making these bearings work?
    which roller bearings do you use? RWC?
    if its RWC's bearing, the kit has several axles which are of difference diameter.
    maybe you are using one that is a bit too small?
    i would also get in contact with chris from RWC. he is very good supporting his customers.
    (https://forums.mtbr.com/shocks-suspe...me-998670.html)
    (https://forums.mtbr.com/member.php?u=234810)
    paging @chris
    Oren
    Jul 2017
    From Fox
    Oh. Disregard....
    Dec 2004
    So you've tried the same bearing kit on two different shocks, or the same shock?
    That's weird because there isn't a whole lot happening in that bearing kit...unless the bearings themselves are shifting while the suspension moves?
    Jul 2017
    Quote Originally Posted by Christopher Robin View Post
    I've actually tried two different Fox bearing kits on two different shocks on two different bikes.
    Reputation: Velodonata's Avatar
    May 2018
    Quote Originally Posted by jeremy3220 View Post
    Are these going on the linkage end that moves more, or the frame end that doesn't?
    Jul 2017
    Quote Originally Posted by Velodonata View Post
    Linkage end
    May 2018
    I think a possible issue could be that these rely on a very good fit in the shock eye, which is notoriously not quite a 100% reliable tolerance. Are there any signs of fretting or other relative motion between the bearing cups and the shock eye during use? The RWC needle bearing kit comes with various fitted axles to solve tolerance problems, this kit is one size fits all and only if you need a 30mm width. From their diagram, Fox calls everything a light press or slip fit.
    Jul 2017
    Yeah it feels like the cup(s) is shifting slightly. I can bounce on the bike to compress the suspension then gently get off and lift the rear while placing a finger on the mount and when it clicks it feels like it's shifting slightly.
    Jul 2015
    I use RWC Roller bearings and haven't had issues, and as others have said maybe it's the fit. Perhaps you could try and RWC and see if it eliminated your clicking with the ability to fit a tighter tolerance.
    Sent from my Pixel 4 using Tapatalk
    Reputation: jimarin's Avatar
    Mar 2005
    I had the exact same problem with mine. No matter what i tried they made noise. The bearing caps have little lips in them and mine showed wear really quickly. I think itís related to side loading during suspension movement. Iíd say that them working quietly depends on if the frame side loads the link at times. I know some people that have them with no issues. Iíve used rwc with success on numerous bikes.
    Thicc Member
    Reputation: TylerVernon's Avatar
    Nov 2019
    These things sound like junk!
    Sep 2012
    I have exactly the same clicking noise on my Tallboy. Not localized it yet, but have regreased and checked all suspension links. Twice. )
    Jul 2017
    Quote Originally Posted by accordnick View Post
    So the way mine clicks is I can bounce to compress the suspension (sometimes it clicks at this point) then I can gently step off the bike and quickly lift the back of the bike up (holding onto the front triangle) and it will click. I can also step off the bike and gently lift the back up then push down on the rear triangle with my other hand to make it click.
    May 2018
    If it's installed and torqued up correctly and the cups are still moving in the shock eye, you will never get rid of the click. I would go with the RWC needle bearing kit.
    Sep 2012
    It's the 100% as mine does. But to get the click I've to push the suspension hard and fast (by a bunny hop or a jump), so it's difficult to diagnose at home.
    Sep 2012
    I've fixed my Fox Roller Bearing. Replaced it by PA6 graphite bushing. )
    No more annoying clicks.
    I'll try RWS needle bearing later (no delivery options now due to Covid).
    Jul 2017
    This is what I ended up doing. Click is gone now.
    Just a heads up on the RWC kit, I've been running them for many years, I'm a big fan, but they all have a little play in them. It's annoying but you won't feel it on the trail. RWC will tell you a tiny bit of play is needed to prevent binding. To me it just seems like poor tolerances. There's really no need to provide multiple size inserts if the bearing and hardware are dialed in with exact tolerances but we are talking about the bike industry. Half of us have creaky pfbb's because our frames or bb cups have sloppy tolerances. Sounds like the fox bearing kit comes down to tolerances. I have the fox kit on my oem shock that was perfect. Zero noise, nice and smooth. Now I'm back to RWC because I couldn't remove the kit to swap over to my new shock. I miss how tight the fox bearing kit was, but on the trail there's zero difference in sensitivity between the two. Needle bearings are great, I just wish they were sealed, or at least self contained with tighter tolerances.
    It's a big off topic but if anyone knows a good DIY technique for removing the fox kit I would appreciate any advice.
    From the parts diagram, could the issue at from part letter C being a bit too long? Couldn't you just file down the end a tad to tighten everything up?
    I had a similar issue with an avalanche rear shock mounted on an Ibis mojo hd. The ti hollow insert was just a tad too wide allowing the shock to rattle around. Filed off a tad and it was good to go.
    83 Ritchey Everest
    95 Bianchi Mega Tube ti
    2015 Kona Operator Supreme
    2015 Kona Process 153
    2019 Kona Process 153 CR 29
  1. Fox rear shock roller bearing kit warning!
    By dv4928 in forum Santa Cruz
    Last Post: 3 Days Ago, 08:05 AM
  2. Fox DPX2 and roller bearing hardware...
    By rscecil007 in forum Shocks and Suspension
    Last Post: 06-14-2020, 12:23 AM
  3. RWC vs Fox roller bearing 8mm x 30mm
    By jazzanova in forum Shocks and Suspension
    Last Post: 01-14-2020, 11:12 PM
  4. Fox rear shock roller bearing warning!
    Last Post: 08-28-2019, 10:47 PM
  5. Rolling speed: High Roller vs. High Roller II
    By ride the biscuit in forum All Mountain
    Last Post: 06-25-2013, 11:53 AM
Members who have read this thread: 107
