Fox rear shock preload adj. ring - how many turns is minimum for safe operation?- Mtbr.com
    Reputation: Bro_cro_xc's Avatar
    Mar 2006
    Hi,
    I have question regarding installing coil on fox van r rear coil shock.
    From the moment when preload adjustment ring touches coil how many turns are minimum for safe operation?
    And BTW what is usually maximum? Is there any rule?
    Cheers,
    Bro
    Aug 2005
    Generally another 0.5 to 1 turn of the adjustment ring.
    Best is just enough preload to keep it from rattling, or coming loose.
    Also, never more than two turns of preload. If you need two turns of preload to get your required sag, go to the next higher spring.
    See here:
    http://forums.mtbr.com/showthread.php?t=47726
    Reputation: Dougal's Avatar
    Minimum is just snug on the spring. Maximum depends on the shock and spring, but generally 6 turns is fine.
    Owner of www.shockcraft.co.nz, Mech Engineer, Tuner, Manitou, Motorex, Vorsprung EPTC, SKF, Enduro
    www.dougal.co.nz
    Mar 2006
    Deoreo and Dougal, thanks a lot for reply!
    Bro
  1. Why only 1 or 2 turns preload on coil springs?
    By aenema in forum Shocks and Suspension
    Last Post: 10-23-2008, 08:15 PM
  2. 2 turns of preload???
    By massmang in forum Shocks and Suspension
    Last Post: 06-17-2006, 11:58 AM
  3. Anyone else bust a preload ring on a fox shock..
    By kattywhumpus in forum Shocks and Suspension
    Last Post: 05-22-2005, 11:39 AM
  4. Rear Shock Spring Rate vs Preload
    By WarrGuru in forum Shocks and Suspension
    Last Post: 02-15-2004, 12:14 PM
  5. 3 full turns of preload?
    By CrashTheDOG in forum Turner
    Last Post: 01-30-2004, 08:21 PM
