fox internal swap- Mtbr.com
Results 1 to 3 of 3
    Reputation: brucexc's Avatar
    fox internal swap
    I have 2016 fox 32 with straight steer tube and a tapered 2015 fox 32 and want to swap the 2016's air spring and damper into the 2015's and the 2015's into the 2016's. Is it possible? From what I've found only the damper will work.
    ODI | SIXSIXONE | SDG | CRANK BROTHERS |
    Reputation: Dougal's Avatar
    The 2016 air-spring requires an compatible set of stanchions with the internal notch in the right place to balance positive/negative pressures.
    So the air shaft has to stay with the compatible crown/steerer/stanchion set.
    Owner of www.shockcraft.co.nz, Mech Engineer, Tuner, Manitou, Motorex, Vorsprung EPTC, SKF, Enduro
    www.dougal.co.nz
    Thank for the information
  1. Fox fork internal swap
    By Oze30 in forum Shocks and Suspension
    Last Post: 04-05-2015, 04:40 PM
  2. Flow EX swap for Arch EX swap anyone?
    By Streetdoctor in forum Wheels and Tires
    Last Post: 11-08-2013, 10:40 AM
  3. Replies: 1
    Last Post: 10-23-2013, 07:04 AM
  4. Replies: 7
    Last Post: 11-07-2012, 08:05 AM
  5. Marzocchi 55 Internal Swap?
    By wackoduke in forum Shocks and Suspension
    Last Post: 07-18-2012, 10:57 PM
