Fox Float X2 shock discussion - Page 2- Mtbr.com
Page 2 of 3 FirstFirst 123 LastLast
Results 201 to 400 of 506
  1. #201
    Reputation: Daxdagr8t's Avatar
    Jul 2014
    So my 2017 x2 finally arrived. For the life of me i can't remove the aircan to check if the volume spacers are in the shock as It was not in the box separately like before. So my questions is, did your 2017 x2 came with spacers inside the shock already or im just shit out of luck.
  2. #202
    Hopefully you took the little screw out. Mine came with 1 extra spacer but I got mine directly from Fox. 2 were already installed and mine can take a max of three. Try Going to fox website for better instructions on how to remove the can and also to look up your shock to see how many it could take. I believe there's a few YouTube videos that might help as well. From what I remember you turn it towards the air valve and it should come loose, it was a little tight for me too.
  3. #203
    Jul 2014
    Quote Originally Posted by bikemuscle View Post
    What screw? Yeah i watched the videos in youtube. I injured my bAck so im pretty weak lol.
  4. #204
    They added a tiny screw on the back of the canister, it's a 1.5 mm hex which is really small.
    Here's the fox link for adding and removing volume spacers:
    2016-2017 FLOAT X2 Air Spring Tuning with Air Volume Spacers | Bike Help Center | FOX
    If you need a good cheap hex wrench set Performance bikes usually stocks them:
    Spin Doctor Hex Wrench Set
  5. #205
    Jul 2014
    They added a tiny screw on the back of the canister, it's like a 2.5 mm I believe which is really small.
    Oh really lol. I just followed this video
    https://youtu.be/389dOdzHWAA
  6. #206
    Jul 2014
    Got it thanks. I feel stupid now lol. Only have two spacers in there.
  7. #207
    Nov 2016
    Hi, just got a new YT Tues with the Float X2 shock. Really pleased with the shock but on my third ride I landed a big jump and it made a horrible clunking noise. It didn't bottom out. Now every time I compress the shock it makes this horrible clunk / thud noise. Everything seems to be working fine - the rebound and compression still works fine. Can anyone please help or give me any advice on what to do. I'm going to Spain in a week for 3 months so really need it sorted in the next few days..
  8. #208
    Try checking your shocks mounting bolts but you probably haven't ridden it enough yet for that to happen but just in case. I know mine have came loose so much that I wanna add some locktite. Actually a lot of my bolts come loose, rear derailer and my fork bumper bolt completely rattled off. Santa Cruz had to send me new bumper hardware and that's only after a few months of riding. I have a really nice torq wrench set and I'm always checking all of my bolts. Good luck and please share what you find out.
  9. #209
    Nov 2016
    Already tried all them. It's definitely the shock making the noise.
  10. #210
    did you remove the can and see if any spacers came apart? My X2 had the black solid ones but I saw the new version contains the red ones that click together.
  11. #211
    Nov 2016
    Quote Originally Posted by gforcephoto View Post
    Thanks. Will give that a try.
  12. #212
    Reputation: zonoskar's Avatar
    How does the Fox Float X CTD compare to this X2? It's missing some settings, obviously, but apart from that? Looking to use either shock on a Specialized Enduro.
  13. #213
    Do any long term users know if it's possible to user service the air can?
  14. #214
    Quote Originally Posted by onzadog View Post
    Answered on STW.
  15. #215
    Reputation: Junersun's Avatar
    Jun 2014
    https://www.ridefox.com/help.php?m=bike&id=682
    Current Bikes
    2015 Transition Patrol AL
    2016 YT Tues AL
  16. #216
    Haha Rick, I just saw that it had been. Thanks.
  17. #217
    Junersun, thank you for that. Having read through all of that, I think I might actually enjoy doing that to a couple of shocks a few times a year if I can get hold of the proper tools.
  18. #218
    Reputation: Dagonger's Avatar
    Dec 2011
    Other than Kashima coating is there any differences in Factory vs Performance X2?
    Fox site has no info at all on Performance series X2
  19. #219
    I'd imagine that if there's a performance version, it would be an OE item.
  20. #220
    Dec 2011
    It was an OE shock but wondering if any internal differences...
  21. #221
    Quote Originally Posted by yeti575inCA View Post
    It only has low speed compression and rebound adjustment no high speed compression and rebound adjusters.
  22. #222
    Dec 2011
    Quote Originally Posted by Rick Draper View Post
    Sent from my SM-G930T using Tapatalk
    Instagram/Youtube- Dagonger
    Yeti Cycles sb45c/sb150
  23. #223
    I'm looking for a new shock and having been disappointed with the monarch plus debonair, I'm now looking to Fox.
    My monarch came with a M/M tune. I assume that the x2 with all its adjustment, Justin comes as it is, but if I go with the float x evol, I need to pick the correct base tune. Is that right?
    One of the things that bugged me with the monarch was ac lumpy feeling when the positive and negative chambers balanced. Three of them did this so I don't think it was just a duff one. I've also noticed similar on a cane creek. Has anyone noticed this on with it the Fox air shocks?
  24. #224
    There is a few different main piston tunes available for the float x2 but with the adjustment available you will be fine to dial it in. The Fox shock will have a slight dead spot where the 2 cambers equalise, thats just the nature of a self equalising negative air spring.
    A off the shelf float x would be a M/M tune.
    Overall I have never been impressed with RockShox shocks, they just aren't that great imho.
  25. #225
    I'd imagine there would be a change at the chamber bleed port. The monarch used to feel like the support collapsed at that point though. Fortunately, that was at 15% travel. My concern is that the Fox port is at 25% which is a much busier part of the travel.
  26. #226
    Apr 2013
    Got a quick question : Does the climb switch / 2 pos. Lever does basically the same thing like turning the LSC all the way in? Or it's something more profound like an actual lockout? I'm having slight bobing on my YT Capra and want to see if there would be an improvement on the climbs with the switch?
  27. #227
    Reputation: kdiff's Avatar
    Quote Originally Posted by Bogdan_mb View Post
    Increasing the LSC a fair amount.
  28. #228
    Apr 2013
    My LSC dial is maxed out but it's still bobing slightly. So is there any improvement with a Switch? I'm just asking if it's actually worth 200$/Ä
  29. #229
    There is improvement but it sounds like you will still get some bobbing. It wasn't a necessity for me as my Nomad pedals/climbs very well. I was curious and figured I could recoup some of the costs in additional resale value. I also got a discount since the shock was in for the recall and service.
  30. #230
    Nov 2016
    Does anyone know where to find the travel reducer to shorten the stroke from 57mm to 50mm or know the outside diameter, I know the shaft is 9mm, of the washer needed to limit travel.
    Sent from my SAMSUNG-SM-G935A using Tapatalk
  31. #231
    Quote Originally Posted by gate View Post
    I'm 155 ungeared and very recently put an X2 on my 2015 Nomad right before a trip to Whistler. I started with in the middle of the Fox recommended settings for the PSI that I chose (160). After a week of riding I had basically backed the LSC out a click to 22 and the HSR a click also. At those settings the shock did feel harsh to me on braking bumps and other fast repeated square edge hits. Not the 'magic carpet' that some people describe, but I loved the performance and control. Was just nearing but not hitting bottom out despite my best efforts and worst jump casing. I really only thought about the shock when I hit the braking bumps. And in those bumps it was very composed and there wasn't a lack of control. So, being not the most confident in my suspension setups I was thinking I had gotten to a setup that may work really well but may also give me some feedback rather than feeling like I'm floating on a pillow. I think it's been said here but one of the best things about that shock is how it transforms the Nomad on technical climbing - supports the mid stroke so the bike stays up in its travel. I went from many pedals strikes to almost no pedal strikes on 175mm cranks.
    Okay back to the light rider issue. On my old Nomad (N2) I put a RWC needle bearing kit on the rear end of the shock and it absolutely transformed that bike, made it way more supple. I would think that lighter guys like you and me may be more affected by stiction in the plastic shock bushings from Fox. So, putting needle bearing kits on one or both ends of the shock are something to consider. I am thinking about doing it for the X2. You've already gone so far as to try changing the oil in the shock, so why not try the needle bearings, right?
    You every get this dialed? I'm 150lbs and running into the same problem.
  32. #232
    Jan 2015
    I opened the air can to check how many volume spacers were in there (3 out of the allowed 3 for my size on a Nomad). Getting the air can off there was a fair amount of friction but it came off relatively easily. But when I install it back there doesn't seem to be much friction (really no static friction) keeping it in place when I turn it all the way, and I'm sure that it is in the right position. Mine does not have the little screw that the later models do. I guess that's why they added the screw? Should I wipe some of the grease off the seals do increase the amount of friction? Not worry about it?
  33. #233
    Nov 2016
    Has anyone else ran into the little set screw stripping? If so how to get it out and what to replace it with. I don't like the idea of cutting a slot, too close to the body.
  34. #234
    Reputation: bachmayeah's Avatar
    sorry for the question in this thread (maybe it has already been postet), but: does anyone know if there was a change in the 2pos-lockout function between '16/17 and '18 models?
    i had a '17 216mm Model in my former nomad and by switching the lever to firm it was nearly a complete lock-out. now with the current nomad and 2018 230*60 model switching the Lever only leads to a very slow compression but it still goes through the complete sag. (altough Fox internal tuned the compression to firm)
    any ideas are very welcome!
  35. #235
    i have a 2018 x2 and after about 50 miles, it started having black marks on the stanchion. looks like somethings rubbing on it. i can clean it off with a towel, but after a few compressions, it'll come back. anyone hit this issue?
    to my knowledge, the shock seems to work still. im still new to the shock so im not sure how i'd test to make sure it's 100% working.
    im running 185psi with 3 click-in volume spacers. it came with the 3 click in spacers from fox, which is odd.
    2017 yeti sb6c turq x01 eagle
  36. #236
    Giant Reign Advanced 1
    Reputation: ka81ua's Avatar
    Oct 2014
    Is there any other tool (cheaper, simplier) instead of 398-00-419 to do step 5?
    https://www.ridefox.com/help.php?m=b...lout&eid=8226#
    "negative air sealhead tool (PN: 398-00-419) with the notches for the negative air sealhead"
    OK
  37. #237
    Nov 2006
    Quote Originally Posted by ka81ua View Post
    I used one of these, worked good.
    https://www.parktool.com/product/cra...ttom%20Bracket
  38. #238
    Reputation: trailbildr's Avatar
    Dec 2004
    I would do a basic air can service on it. I imagine your seals are dry. Fox requires 5ccs of Float Fluid with every service and I think that's all you'll need. If you are opening the can, you might as well just replace the seals but you may be able to get away with just the can lube. You can use 15wt if that's easier.
    mk
    TrailWerks Cyclery
    TrailWerks Suspension Service
    trailwerkssuspension.com
    trailwerkscyclery.com
  39. #239
    Quote Originally Posted by spokeywheeler View Post
    Yes, we can verify this will work. It is what we use, but be careful not to slip as it will scratch the air tube. We also spent some time rounding over the sharp edges to make it more friendly. Also fully compress the air can so it protects the air tube.
  40. #240
    Thanks for the tip. I rejected the idea of home servicing the X2 not because it looked too difficult (the Fox guide looked really clear) but because of the tooling cost.
    Does anyone have a list of alternatives like the one above that will work? How much do we actually need to spend to make it happen?
  41. #241
    Reputation: bikeboardorblade's Avatar
    Anyone have experience with Fox's warranty? I've lost all rebound dampening and it's making a squelching sounds like there's air in the system. Yay.
    Sent from my Pixel 2 XL using Tapatalk
  42. #242
    Dec 2011
    Quote Originally Posted by bikeboardorblade View Post
    Fill out an Ra request online. I had an enail reply next day with shipping instructions
  43. #243
    How's the turnaround? How are they to work with?
  44. #244
    Nov 2006
    FWIW I used the Park HCW-5 tool because I had it in my tool box already and I was looking to see if some other sort of spanner would do it instead of the specialty fox tool. I wrapped the shock body with an old tube to protect it. the good thing is the park tool engages pretty well and I didn't have any issues with it slipping.
    I didn't do a full service on the shock however. I just wanted to get it apart enough so that I could get some float fluid behind the main wiper seal. I made a clamp block for the air sleeve with wood and using that and the spanner I was able to unthread the front part of the seal and squirt some lube into it.
    Not a replacement for a proper service by any means but mine was running dry and after the addition of some float fluid it's back to normal.
  45. #245
    Dec 2011
    Will post when in done. I just sent in on Fri.
  46. #246
    Similar thing happened to mine (no compression damping and squelching sound) after 600 miles. Turn around time for warranty was about 3 days after they got it.
    Props to fox for an easy process but Iím bummed it died so quickly.
  47. #247
    I think I've heard that there is an issue but Avalanche have a fix.
  48. #248
    Quote Originally Posted by jminus View Post
    The turn around is encouraging, but discouraging that it's happening more and more. I know a few other people locally with similar issues. How has it since getting it back?
  49. #249
    Itís been fine but due to weather and work it has only accumulated 160 miles of riding. Iíll probably get to 600 again by spring and Iíll follow up here if it dies again. I was killing my CC shock every 600 miles so thatís become my benchmark.
  50. #250
    Reputation: Dougal's Avatar
    Anyone here running the Fox R2 oil?
    I'm looking for viscosity info. It's not on the front of the bottle.
    Owner of www.shockcraft.co.nz, Mech Engineer, Tuner, Manitou, Motorex, Vorsprung EPTC, SKF, Enduro
    www.dougal.co.nz
  51. #251
    Aug 2015
    1. Do you really need the "X2 bullet (398-00-418)" to reinstall the rebuilt bearing assembly onto the shaft? Can't you just carefully place it on the shaft by hand? Is this to prevent the threads from scratching the inside of the bearing assembly?
    2. What other creative options do you have other than using the DHX2 shaft eyelet (213-01-460) to prevent the shaft from going into the damper? Can't you use two nuts?
  52. #252
    Aug 2015
    I had to send my x2 in for warranty work since it cavitated. Its been a week so far, hopefully will get it back in a few days. I'll have to learn to rebuild this on my own next time when its out of warranty. Guess I'll have to figure out the 9mm clamp. Thats the only thing im missing. Gonna try the rubber golf clamp i have laying around, hopefully will do the trick.
    Sent from my SM-G930V using Tapatalk
  53. #253
    Oct 2014
    What's a 9mm clamp? Photo (link) please..
    OK
  54. #254
    Aug 2015
    You'll need to look at the float x2 rebuild instructions on fix's website. There are too many tools. It basically just clamps down on the damper rod. It costs $80 and its over priced . They also sell one for the body as well. I dont want to pay 80 for a metal clamp. I havent been able to find a good quality alternative.
  55. #255
    Quote Originally Posted by jacksonlui View Post
    You need quite a deep 9mm shaft clamp to remove the end eye.
    Also its not cavitated the shaft seal has failed and allowed oil into the air can.
  56. #256
    Aug 2015
    The report directly from Fox said its cavitated. Something about an out of date oring in the bearing assembly. But they used the word cavitated as the reason.
  57. #257
    Oct 2014
    Seriously, I don't see a 9mm clamp... Show a pic plz
    OK
  58. #258
    Nov 2016
    http://lmgtfy.com/?q=Fox+9mm+clamp
    Sent from my SM-N950U using Tapatalk
  59. #259
    Aug 2015
    Anyone run their shock with the red limiter removed? I only use 1 spacer and 215psi with hsc almost all the way out.
    The limiter is only there to prevent someone from using too many spacers. Shouldn't be a problem if the limiter is removed if i use no more than 1 spacer?
  60. #260
    fuggansonofahowa
    Reputation: Hawseman's Avatar
    I thought that the red spacer was roughly the same volume of a single spacer. It doesn't look like it, but the internet told me that....as well as Tide Pods make a good snack.
  61. #261
    Sep 2014
    I can find it at the moment but there is a video of Chris porter pulling the red x2 limiting spacer out and putting in more than the fox specified number of spacers into an x2. I think it was when he was setting up a geometron for a customer. I think he said unless you are doing anything crazy you shouldn't run into issues but it is at your own risk.
  62. #262
    I concerns me that they used the word cavitated since itís actually aerated....cavitation is dynamic and hard to feel at all.
    They originally used a quad ring that proved to not be up to the task and since late last year it has been changed to an o ring.
    As for tools itís a top of the line shock ffs.....if you donít want to pay a pro to do it at least make sure you have a couple of good tools! Getting the air can completely off needs good clamps for the can and 9mm shaft so spend a bit of money there because itís easy to scratch something!
    Instead of a DHX2 eyelet I used to use the shocks own eyelet and it worked fine.
    The bullet tool stops the seal getting nicked by the edge of the shaft and would be a pain to fit without it! Considering the fact that you are probably rebuilding the shock because that seal was leaking it makes sense to do it properly...
    Finally set aside a couple of hours for the bleed process alone if you want any hope of doing a remotely good job! Some kind of syringe to vacuum the shock is crucial too
  63. #263
    Sep 2014
    Quote Originally Posted by aussieprime View Post
    http://www.mbr.co.uk/news/suspension...th-mojo-368074
    From 2.50 onwards
  64. #264
    Aug 2015
    Thanks. I agree on the bullet tool, its only $15.
    $80 for a 9mm clamp shaft is expensive. $160 for both clamps. If there is no other option then i guess its better than nothing.
    Fox used the word caviation in their paperwork from the tech department.
  65. #265
    Oct 2014
    Hope someone will ever make a detailed video about how to deal with that "cavitation problem"..
    OK
  66. #266
    Oct 2014
    Is thete some good simple detailed video how to setup float x2 I mean LSR/HSR and LSC/HSC?
    I'm new user of that shock and honestly I don't exactly understand how to feel that some settings are bettet than others.
    For example, LSR - 6 clicks or 7 clicks, etc..
    OK
  67. #267
    You can start with the recommended settings in the fox manual but also check out Vorsprungís Tuesday tune videos, specifically the one or high speed/low speed damping and the one about more spring or more compression
  68. #268
    Oct 2014
    Thank you for advices.
    Could you, please, type links on your videos so I wouldn't make a mistake?..
    OK
  69. #269
    yeah same here. mine was making slurping noises too. i sent it to fox last week. they said it was cavitated also and some out of date internals.
    https://youtu.be/Tt2wnLvT8hA
    i only had the 2018 fox x2 for 3 months with maybe 10 rides due to shitty weather.
    they are sending it back on monday. hopefully all is ok.
  70. #270
    Aug 2015
    Same here. Had it for a few months and same noise. Sent it in and said it was cavitated and said an oring needs to be updated. Everything is working so far.
  71. #271
    man i was so tempted to just get a dhx2 or an 11-6 lol. raging that i can't ride, and this weekend is the first free and nice weather weekend in my area.
  72. #272
    Oct 2014
    But which one o-ring exactly is the problem??
    I don't have ane Fox service nearby so I have to deal with it by myself..
    OK
  73. #273
    no idea. i dont know enough about the internals to say. and fox didn't give me details. thats literally all they communicated to me.
  74. #274
    More IFP pressure.
    Same problem as pretty much every fox air shock ever.
    www.dougal.co.nz
  75. #275
    Quote Originally Posted by Dougal View Post
    More IFP pressure.
    hey dougal,
    can you elaborate please? the last thing i did to the x2 was increase the air from 195 to 210psi, but i dont think that would cause my slurping issue
  76. #276
    More IFP pressure.
    The main shaft seal is the issue, oil ends up bypassing it and ending up in the aircan. They have moved from a quad ring to a regular o-ring on that seal now apparently. The tech docs show it.
  77. #277
    Nov 2016
    Quote Originally Posted by useport80 View Post
    hey dougal,
    He's talking about the IFP chamber. It's pressurized seperately from the main air chamber and isn't something that a general user is advised to touch from Fox.
  78. #278
    Oh, they did a CC?
    What's with everyone getting seal groove dimensions wrong these days causing leaks? Did all the old engineers retire?
    www.dougal.co.nz
  79. #279
    Oh, they did a CC?
    yeah I canít get how that kinda thing happens, the replacement polyurethane seal is just like what every other fox ever has used so why not use it from the start?
  80. #280
    Oct 2014
    FLOAT X2 Part Information | Bike Help Center | FOX
    Can someone please show the part number of "problematic" ring (/s)?
    OK
  81. #281
    Its in the bearing assembly, the main shaft seal.
  82. #282
    Oct 2014
    please, point at picture exactly, or write a part-number if it's written somewhere there on fox's page.
    Thank you very much
    OK
  83. #283
    Oct 2014
    https://www.ridefox.com/fox17/img/he...6-085-KITc.jpg
    029-03-022 or 035-06-000 or 029-08-123 or some else ??
    OK
  84. #284
    PU Orings are usually used because they're tougher and don't slice up going past the rebound port on the shaft.
    Makes me wonder if Fox's issue is assembly related rather than seal/groove size?
    www.dougal.co.nz
  85. #285
    Aug 2015
    From my rma paper:
    029-08-123
    O-ring 8.5mm id x 2.5mm cs
    Polyurethane parker 4300/93A or disogrin 9250/90A
    I dont know what this means but that's what's on the paperwork
  86. #286
    Reputation: Bizarro's Avatar
    question.. about to order a new frame and I want to get the the DHx2 coil but can't find concrete info on a heavy weight spring for my size... about 250-255 at 6'2"
    Any big boys running this shock with a heavy spring for that weight? Or I might just get the frame with the DHx2 can... hummmm
    k n o ll y r o c k s
  87. #287
    Quote Originally Posted by Bizarro View Post
    i tried looking at some of the internet spring calcs and i usually get these results:
    plush=350-375 spring
    firm=400-450 spring
    for a 195 riding weight.
  88. #288
    ohhhh really...thanks man. Yeah having a hard time definitively knowing if this will work for my phat ass. I don't see why not and it's FOX so i assume they have a big boy spring. But am I wrong or am I seeing these springs going for $130 around the sites??
    This is crazy for a steel spring. I really don't understand the pricing on this. Not Ti.
  89. #289
    yeah it seems like $130 everywhere...
  90. #290
    Oct 2014
    029-08-123
    so this one is the source of cavitating problem?
    Does anyone know if this o-ring come in a kit 803-00-951 Seal Kit: Float X2 Spring and Damper Rebuild 2016-2017 all sizes except 8.75x2.75 ( https://www.bike-components.de/en/Fo...oat-X2-p44547/ ) ?
    Or it comes only in bearing assy kit 812-06-085 ??
    https://www.foxracingshox.de/905/201...groin-9250/90a is it the one? Any other online deals like ebay or similiar?..
    OK
  91. #291
    Aug 2015
    Not sure. Its written on the paperwork
  92. #292
    I've had this part on both my X2's replaced/installed as well. Sent them both back in when they starting squelching from cavitating.
    But now the one on my Nomad makes a "squeak" type sound when it's compressed, almost like the seal is too tight and hasn't broken in, or the seal needs to be lubricated? Both of my X2's do this now with the new seal, so I'm guessing this is normal? Anyone else's doing this?
  93. #293
    These shocks are not cavitating. I wish Fox would stop telling people this is whats happening.
  94. #294
    Sep 2012
    I put an X2 on my new Bronson and got my first ride on the bike the other day and am concerned if it can handle my weight and riding. Right now, I'm about 225 geared up, needed the max of 250 psi to achieve 30% sag and have the max 2 volume reducers in the can(200x57 stroke). Since this is my new "big" bike, compared to my Ripley, my hope is to tune it to prevent bottom out on some occasional 4 ft. drops to flat and handle chunky trail without doing the same. I started with Fox's recommended compression settings(12-14 clicks) for the can pressure being used and went with Vorsprung's recommendation to run HSR all the way in and use LSR to tune(for reasons explained in their videos)appropriate rebound.
    Anyway, I had a few bottom outs on runs with 8-10" type rocks, worked on speeding up rebound to help prevent packing down being the cause. And was using all the travel on some slower 2-3 ft. drops to flat. I know bottom outs can't be eliminated, but it really wasn't much different than my 120mm travel Ripley. And overall, the shock/bike just felt stiff on the chatter. Backed off the LSC, increased HSC and not much better. My feeling is I need more ramp up, but I'm maxed on reducers, and I need less overall air to get a plusher ride on the chatter, but this will contribute to further bottoming. At this point I just can't see the LSC/HSC adjusters, with maybe a little more rebound tweaking, getting me to my goal. Any advice?
    9:Zero:7 Whiteout
    Ibis Ripley LS v2
    Ibis Ripmo
  95. #295
    Aug 2015
    If its not cavitated, what is it so we understand it better?
  96. #296
    Yeah, that'd be good to know if you can explain when you get time Rick. I was just repeating what Fox told me...
  97. #297
    The main shaft seal has failed and has allowed oil to bypass it and enter the air can, the IFP bottoms out in the air can so it is unable to function and then air gets dragging into the damper through the failed main shaft seal.
    This is cavitation, and is not whats happening in all these failed X2 shocks, hence the change to the same pu o-ring as all inline CTD and DPS shocks use on the main shaft seal.
    https://www.youtube.com/watch?v=ejirKoI2jCs
  98. #298
    Nov 2015
    O-ring 029-08-123
    8.5mm id x 2.5mm cs
    This o-ring failure is the cause of the problem and its in bearing assembly.
    I have the same problem and there is not any fox service center or bike suspension service where i live so i built required tools in machining shop for very cheaper prices than fox ... and i will rebuild it myself at home . I upgraded my shock on giant reign with this shock last year and now it needs a rebuilt .
    Here is the photo of the o-ring
    Attached Thumbnails Attached Thumbnails Fox Float X2 shock discussion-20180318_004748.jpg
  99. #299
    Oct 2014
    New question here.
    is that thee o-ring?
    it doesn't look like O-ring, it's more like X-ring. I guess it's impossible to find at usual supply-stores with resin rings and etc.. ((
    OK
  100. #300
    Oct 2014
    Fortunately, this x-ring presents in 803-00-951 Seal Kit )
    OK
  101. #301
    Fox have removed the quad ring and replaced it with a PU o-ring to prevent this failure happening.
  102. #302
    fuggansonofahowa
    When did they start doing that? Do I have to worry about my recently purchased MY18 sounding like a cheap adult movie after a few rides?
  103. #303
    Oct 2014
    Can you please show it or smth similiar? Im no sure I got your info in right way (engl is not my native).
    What are the chages about new ring - is it only material (from resin to polyurethane) or the shape also (from unusual X to simple O)?
    OK
  104. #304
    Quote Originally Posted by Hawseman View Post
    Late last year/early this year. All the new seal kits come with it in now instead for he quad ring. The tech docs show the part number change as well.
  105. #305
    Material and shape.
    They were using a -110 N70 quad ring and now they are using a 8.5 x 2.5 PU o-ring.
  106. #306
    Oct 2014
    could you please give a link to tech doc or at least write a part number of new ring?
    OK
  107. #307
    Oct 2014
    Material and shape.
    I just bought full service seal kit and there's X-ring..
    I guess ididn't get new oring?..
    So, in future i should just find some pu 8.5 x2.5 in supply stores and will be fine?
    OK
  108. #308
    Oct 2014
    If it is the one - https://www.foxracingshox.de/905/201...roin-9250/90a# than it's dated at 2016 but you said it's rather new ring...
    OK
  109. #309
    2018 Tech doc:
    Part number: 029-08-123
    Seal kits have all been updated, you must have a older kit.
  110. #310
    Its been used in other fox shocks as well, not just the X2.
  111. #311
    So what are the odds that my 2018 Float X2 that I bought recently but says it was manufactured on 7/27/2017 on the sticker on the box has the new o-ring?
  112. #312
    on my repair documentation from fox, it has this. i dunno if it's the same o-ring or quad ring you guys are referring to.Fox Float X2 shock discussion-20180316_180227.jpg
  113. #313
    Oct 2010
    Read through this whole thing and still unsure on a few things.
    After releasing all the air to set sag should I full open or close all dampers? Or leave them where I should set them?
    Ibis manual alludes to starting at fully closed to set dampers, but doesn't specifiy if I should close them when re-inflating the chambers.
    Quote Originally Posted by WoodstockMTB View Post
    Open all the setting up on the damper when you set your base level sag. Then dial the damper settings in from fully closed. You use fully closed as its always a set point, sometimes fully open can vary between different shocks even though they are identical.
  115. #315
    Oct 2014
    So when filling shock with air all settings should be fully opened (means fully counterclockwise turned)?
    OK
  116. #316
    Oct 2014
    My 2018 has failed with the same issues, squelchy, no rebound, you can hear oil sloshing around when shaking it so I guess thats the damping oil in the aircan.
    No warranty despite only 12 months old as I bought it as a grey import. Still cheap enough so not an too much of an issue, its off being serviced currently.
    I'm a bit peeved though as I got this to replace a garbage ccdba that had the same problems on a very regular basis.
    Would a dhx2 coil have the same fault? As I'm mighty tempted to sell this when it comes back & get a coil.
  117. #317
    Quote Originally Posted by mcozzy29 View Post
    DHX2 has other issues, one been eating the ti nitrate shock shafts, they have changed the sealing on these for 2018/9 so hopefully it will have fixed them as well.
  118. #318
    Oct 2014
    could you please describe what they did service in your shock?
    I guess I'll have same issue somitime but I'd like to service it by myself..
    OK
  119. #319
    Anythung other than fitting volume reducers in an X2 involves significant disassembly and specific tools. You can't even service the air can without having to change the oil and bleed it. The instructions are in the fix website and look straightforward enough but the tooling is silly expensive.
    Still debating if it's worth it. Although it would mean I service it more often.
  120. #320
    Oct 2014
    was it for me?
    if yes, anyway I don't have NORMAL official FOX service nearby so I have to (and I like to) do all the services by myself.. )
    Tha main ? here is - what and how to service if we are talking about well-known issue?!..
    OK
  121. #321
    Sep 2014
    Looks like my 2018 X2 is suffering from the bad seal issue, making the sucking sound and air can full of oil. Sending it back to Fox, see what they say. Was built June 2017 so definitely does not have the updated seal. Luckily I kept my Monarch + for a backup!
  122. #322
    Oct 2014
    Would you, please, then write here what they've done, what changed,...
    OK
  123. #323
    Oct 2014
    the 2019 seal kit fitted, so i assume mainly the dodgy xring has been replaced by an oring.
  124. #324
    Oct 2014
    Is there a part number for 2019 seal kit?
    OK
  125. #325
    Yes the same as the 2018 kit, its just been updated iirc.
  126. #326
    Mar 2013
    I was told that the 2019 x2 would not be available aftermarket in the 210x55 size, only as OEM. Can anyone verify that with authority?
  127. #327
    Reputation: rondre3000's Avatar
    Quote Originally Posted by lycra View Post
    Were you told that by Fox?
    Sent from my Pixel XL using Tapatalk
  128. #328
    Mar 2013
    Quote Originally Posted by rondre3000 View Post
    Fox rep via LBS
  129. #329
    Fox rep via LBS
    Contact Fox directly either by phone or email. They are really good bout interacting with end users.
  130. #330
    Mar 2013
    Confirmed by Fox, that size is OEM only.
  131. #331
    Sep 2014
    Shock came back today, same issue as others posted earlier. Replaced the quad ring with new updated O-ring. Sucks it had to go back but at least they turned around in 2 days.
  132. #332
    Aug 2015
    Surprised not a lot more youtube videos on full service. Maybe the expensive tools are preventing a lot of diyers
  133. #333
    The Fox instructions are clear enough but yeah, the tool are too expensive. I'd be willing to spend maybe half the price of the shock on tooling, but to do it properly actually costs more than the shock itself.
  134. #334
    Aug 2015
    The only thing that's outrageous and i cant find an alternative for is the shaft clamp. Its $80 and hard to justify. I havent been able to find something half the price which works.
  135. #335
    Oct 2014
    New question here.
    Shaft clamp 803-00-967 ?
    OK
  136. #336
    www.dougal.co.nz
  137. #337
    Nice. If I was closer, I'd be after you for a set. Unfortunately, I don't think it's possible to actually be any further away from NZ than I am currently.
  138. #338
    Aug 2015
    Not that onethe 9mm air shaft clamp
    398-00-416
  139. #339
    I don't make tools for sale normally. Just for our own workshop use.
    www.dougal.co.nz
  140. #340
    Aug 2016
    Hi, anyone here sent a 2018 X2 to avalanche to be modified? I did mine and Iím glad i did. Shock works very nice compare to stock. Only question is, is it normal for the stanchion to be dried? I remembered before the modification, it used have a little lubrication on it. Also, i noticed that when Iím bouncing at parking lot, the stanchion getís warm to touch. Maybe because of lack of lubrication?
  141. #341
    398-00-416
    Find a local machine shop and ask them to make you a 9mm alloy shaft clamp.
  142. #342
    Oct 2014
    No 416 tool....
    OK
  143. #343
    No 416 tool....
    The 9mm clamp?
    They're just normal workshop tools. I didn't consider them worth taking a photo of. I do have a Swedish dude twisting my arm to make a set of clamp blocks though.
    www.dougal.co.nz
  144. #344
    Oct 2014
    The 9mm clamp?
    Sorry, misquoted you.
    My comment was for:
    398-00-416
    OK
  145. #345
    Oct 2014
    I thought the most expensive tool for X2 servicing was http://forums.mtbr.com/shocks-suspen...l#post13697382
    but now people say about 9mm clamp... Strange, cause even PT has some vice clamp with 9mm for cheap..
    OK
  146. #346
    Reputation: travman's Avatar
    What is the clamp dia. for what you made - if you don't mind sharing? I see it stamped on the clamp but cant read it. Haven't been able to find the info to make my own clamp for the air can. My neighbor has a wood shop and i was going to DIY one using a block of ash.
    For the 9mm clamp i was going to buy the RS clamp set - $35.00 which is has a 9mm clamp from what i read. Much cheaper than fox.
    https://cdn.bike24.net/i/p/0/8/132680_00_c.jpg
    Only part i am hesitant on for DIY is the hand bleed but going to try it and see what happens, if it doesn't work then I will send it out for a vac. bleed.
  147. #347
    Quote Originally Posted by travman View Post
    The tricky part is the clamps need to be wide enough to reach outside the air can and fit in your vise. It gets real tight on the shorter stroke models too. The rockshox clamps are too narrow to work on most vice/shock combos
  148. #348
    Here's the clamps I use and a rockshox clamp next to it (brass)so by all means make them but make sure they are wide enough and narrow enough
    Fox Float X2 shock discussion-img_1007.jpgFox Float X2 shock discussion-img_1008.jpg
    Attached Thumbnails Attached Thumbnails Fox Float X2 shock discussion-img_1004.jpg
  149. #349
    Quote Originally Posted by JohnnyC7 View Post
ID:	1205390Click image for larger version.
    Thanks for the photos - i see what you mean by the width and thickness being critical, gives me something to go by when making the clamp. Still trying to locate the hole size for the air can clamp, would like to have everything ready before I start the rebuild so not trying to make these things on the fly.
    thanks again for the photos!
  150. #350
    Oct 2014
    Could you please paint on your photos to show - what thicknes and width are important?
    Thank you!
    OK
  151. #351
    Thank you!
    The depth of the shaft clamp. It cannot be too deep from top to bottom (hole drilled through it1) but it needs to be deep side to side (with the hole in the middle measured out). If you open one up are you 100% sure you will know what you are doing? I don't meant to sound rude but these are pretty basic questions you are asking about.
  152. #352
    Aug 2015
    How rude! LOL.
    Please give us an update on your rebuild. Looking forward to it
  153. #353
    57mm wide and 16mm tall for the clamps would be sweet, mine are about 55x19 but s little extra room is nice. Sorry I keep forgetting to measure the air can although it is pretty easy to slide the outer can and get to it!
  154. #354
    Jul 2018
    DIY 2017 float x2 dissasembly
    So I decided to rebuild my shock on my own. It made the same sound everyone else has experienced and felt the exact same way. It had the Sloshy and slurpy sound when the shock is compressing and rebounding. Here are my findings hopefully to help everyone learn about whats going on, and open up more discussion. I want to point out that I'm not a professional shop but a mechanic by trade and I don't have the professional tooling fox has to do rebuilds.
    https://youtu.be/I0gKowl6yNM
    This was the initial sound the shock made. I tried to ride it for a few hours and the problem persisted. The sound did not go away and Compression/rebound settings did not work. If I removed the shock and shook it, I could hear fluid sloshing around inside. For the process I followed the fox directions for dissassembly.
    2016-2018 FLOAT X2 Rebuild | Bike Help Center | FOX
    To remove the negative air seal head I used the park tool mentioned before.
    Now things got interesting because I didn't have the proper press tools so I had to get creative. i had wood laying around to cut up and use for the outer air sleeve.
    Now for the 9mm shaft I used wood again to make another clamp.
    once I had the shaft free I checked again to see where the noise was coming from and again it was still inside the piston. There was no sign an oil leak into the air can so I had to dig deeper.
    https://youtu.be/uz9AGLp05bE
    It was time to take apart the bearing assembly. After the ifp was relieved of all air pressure, I removed the bearing assembly/piston and noticed that oil was escaping pressurized. It leads me to believe that the failure of the shock is the ifp o ring and allowing air to leak into the damper oil.
    https://youtu.be/DDHnAiE65MM
    I'm confused at this point because everyone who had the shock serviced by fox points to a different part number on the service invoice. The part that appears to have gone bad here is just the o ring around the Ifp. Does anybody have any more info about this or is my situation a rare occurrence? I think somebody had mentioned that Ifp was leaking but others said the x ring in the main bearing was leaking oil into the air can. let me know your thoughts.
  155. #355
    Aug 2015
    When i sent mine in for this issue they told me that they've "installed updated oring on bearing assembly"
    Not sure of accuracy but thats what they told me when i asked.
  156. #356
    Jul 2018
    then only other way is that the bearing seal is in fact actually bad and air is getting in from the air can. I opened mine expecting to see oil in the air can but ultimately it was air in the dampener.
  157. #357
    Quote Originally Posted by VENOM2034 View Post
    The oil is bubbling as air has entered the damper from the air can.
  158. #358
    Jul 2018
    Got it. I had it backwards. I installed the rebuild kit and it was good to go noise went away and no more air in the shock. Total time was 2 hours while I figured things out and took pictures/videos.
  159. #359
    Oct 2014
    pictures/videos.
    would you upload it?..
    OK
  160. #360
    Sounds accurate to me, bearing assembly is another name for the seal head that is usually the culprit
  161. #361
    Jul 2018
    I forgot to ask earlier and wanted to make sure. In the rebuild kit were two seals that look identical. Is the black one the updated seal for the bearing assembly?
  162. #362
    No the white one is, the black one is the bottom out bumper.
  163. #363
    Is this a bad seal? Shock is never used and settings are close to recommendations.
  164. #364
    Jul 2018
    If the compression/rebound settings donít do anything then thatís pretty clear itíll need the seal updated. Take it out and shake it, if you hear fluid sloshing around itís got air in the piston.
  165. #365
    Oct 2014
    is there some easy way just to remove air?
    OK
  166. #366
    Jul 2018
    Easy if you can rebuild it. Thereís no way to release the air without stopping it from happening again. I tried it the first time around without swapping the seal and on the first few cycles it leaked air again.
  167. #367
    Oct 2014
    One question about settings (I still can't set it in best):
    what to change if bike throws me up every time on line of roots and small rocks?
    I shoul dial LSR/HSR more to closed position (almost fully clockwise) so shock would return slowlier, right?
    p.s. sorry for bad english.
    OK
  168. #368
    Reputation: MarinCRO's Avatar
    Jul 2013
    It could be few reasons for this.
    Your pressure or compression can be too high so the shock doesn't absorb as much and pings off rocks and roots.
    Otherwise it's rebound that's too high. You can do a curb test by riding off a curb and seeing how shock responds. It should stop after the first rebound and not cycle more than once.
    All of this of course takes into the account you're riding standing and not sitting down all the time.
  169. #369
    Oct 2014
    Thank you.
    Problem appears when I'm sitting..
    OK
  170. #370
    Sep 2014
    If you are getting bucked on repeated hits in close proximity could be the rebound is too slow and shock is packing down. If it's single hits bucking you then likely rebound is too fast. I would suggest finding a line where the problem is showing up and ride it back to back, changing the settings one at a time in between until you nail it. You'll know pretty quick if going one direction makes it worse or better.
  171. #371
    Have a work through the guide in here and tell me if it helps:
    http://forums.mtbr.com/shocks-suspen...e-1084380.html
    https://www.shockcraft.co.nz/technic...on-setup-guide
    www.dougal.co.nz
  172. #372
    Fox have a retro fit kit available to upgrade the air can and bottom out bumper to 2019 specs. Its not cheap though as it has inner and outer air cans, a new negative air seal head, replacement shaft, replacement bearing housing, new bottom out bumper and a new eyelet.
  173. #373
    Aug 2010
    would you have a link or part number Rick by chance ?
  174. #374
    Quote Originally Posted by karpiel View Post
    What size is your X2?
  175. #375
    Aug 2010
    222 x 70
  176. #376
    222 x 70
    803-01-296.
  177. #377
    Aug 2010
    803-01-296.
    cheers Rick !
  178. #378
    Sep 2013
    Can anyone steer me towards info about fitting a 2018 Specialized X2 to a 2016 Enduro comp? Need to make sure it fits by canít find much info...thanks
  179. #379
    Sep 2014
    Fox posted the 2018 to 2019 conversion kit part numbers on their website, part way down right before the assembly drawings: https://www.ridefox.com/fox17/help.php?m=bike&id=864
  180. #380
    Reputation: kwapik's Avatar
    Feb 2016
    Quote Originally Posted by xOffxThexLipx View Post
    Quote Originally Posted by gasmanxj View Post
    Also, Bikeyoke makes upper links for the Enduro to run non-stock shocks. I'm not sure if this could help you or not.
    https://www.bikeyoke.de/en/bikeyokes...alized-enduro/
  181. #381
    Oct 2014
    200x57
    1) to upgrade from 2018 to 2019 should I buy 803-01-317 + 803-01-294 or only 803-01-294?
    2) can't find any online-store with those kits..
    OK
  182. #382
    200x57
    You need both parts.
  183. #383
    Oct 2014
    I'm confused - I just can't find it at any online-stores...
    OK
  184. #384
    They are new parts. It will take a while to filter down to the online stores.
  185. #385
    Nov 2015
    Rick could you please let me know why Fox changed damper oil in x2 from 10wt red to 5wt clear ?
    and is it possible to use maxima 5wt plush or maxima 5wt racing fork oil in fox x2 ? because its cheaper and more accessible .
  186. #386
    Jul 2018
    I donít think the cst and vi values will match the required oil from fox.
  187. #387
    Maxima oils have a better VI than Fox R3. That stuff is nothing special at all. Fox R2 is much better.
    www.dougal.co.nz
  188. #388
    Nov 2015
    I think the best match would be:
    Fox R3 5W (damper oil) 15.8cst @40C / 4.07cst @100 c ====> Maxima racing fork oil 5W 16.2cst @40 c / 4.4cst @100 c
  189. #389
    Dec 2015
    you wont feel big difference. My dhx2 used fox 10wt. While serviced silkolene 2,5wt was used. Now I have to add more clicks but shock stopped spiking.
    Looks like thinner oil allows you (light person) to use more shim controlled damping. Also oil temprature thickness change is lower.
  190. #390
    Quote Originally Posted by nikon255 View Post
    Bingo. Which is why other suspension companies were using ~15 cSt oil for 2 decades before Fox was.
    Their use of 7wt and then recommending 10wt in service was bizarre.
    www.dougal.co.nz
  191. #391
    Dec 2015
    btw I feel like supergliss 100k gives damping by its resistance for shearing. When thinner oil is used for bath, fork even rebounds faster. Am I haunted or thats true?
  192. #392
    In the warm it's good and the slipperiness beats the fluid shear. At 0C the extra damping is significant. It's a few thousand cSt at that point.
    Which is why we do Polar Lubes for winter use.
    www.dougal.co.nz
  193. #393
    Jul 2013
    I was thinking of upgrading my X2 with lockout lever and having an oil change in the process.
    Guy who works at Fox recommends stock 10WT oil saying it doesn't really make a difference for heavier person (I'm 88-90kg). Would that be correct or would lighter oil still be "smoother" even if I compensate by using more damping. My riding temperatures range from 10-35įC depending on the season.
  194. #394
    Oct 2014
    OK
  195. #395
    Oct 2014
    What settings will help to prevent bottom-outs?
    HSC ? Which way?
    OK
  196. #396
    Aug 2015
    Clockwise
  197. #397
    Oct 2014
    What can be the reasons if shock lost pressure during one short ride? What to check? What to change?
    From 160 to 120.
    Fox Float X2 (2018)
    OK
  198. #398
    I am thinking of having the clamps 3d printed and see if this works, would be fairly cheap. Any idea on the actual diameter of opening needed for 9mm and air sleve clamp? Also any idea what oil weight is used in 2017 x2 with light tune and what could be used as alternative for fox overpriced oil?
  199. #399
    Quote Originally Posted by ahmad22 View Post
    O-ring 029-08-123.
    8.5mm id x 2.5mm cs
    would you mind sharing actual diameter of the opening for 9mm and air sleve clamps?
    Aug 2014
    Fox X2 Performance - 3rd Rebuild
    Hi all,
    I was wondering if you could please help me make a decision - persist with X2 or replace with a different shock.
    I have a Fox X2 Performance 216x63mm that came stock on my Intense Tracer. It has the 250 PSI aircan limit. I weigh 110kg ready to ride, and according to the Intense owners manual, 250PSI suits a 104kg rider, so I am exceeding (slightly) the limits of the design in that regard.
    The shock has just been rebuilt under warranty for the third time. Each rebuild has been to fix the squelching/lack of rebound issue, then two months later its back again.
    Do you think that the damper failure has anything to do with heavy rider weight?
    Apparently this time they have changed to the new "updated" seals so that it wont ingest air into the damper and squelch again. I assume that this is the change from the X to O ring?
    So assuming that they have replaced all of the seals with the updated ones, am I likely to get a year or two of problem free running?
    Otherwise, I was thinking of buying a Cane Creek Coil IL and selling the rebuilt shock.
    Thanks in Advance.
  1. Replies: 5
    Last Post: 06-28-2014, 08:36 PM
  2. Fox Float Shock 7.25/1.75 shock measures 190mm/50mm ?
    By marty202 in forum Shocks and Suspension
    Last Post: 03-13-2014, 03:47 PM
  3. Float CTD shock
    By frenk in forum Turner
    Last Post: 09-03-2013, 06:01 AM
  4. Replies: 5
    Last Post: 07-16-2013, 02:37 AM
  5. Need some info on Fox Float R AVA shock
    By MiWolverine in forum Shocks and Suspension
    Last Post: 04-20-2012, 10:55 AM
Members who have read this thread: 396
