Fox Float Factory DPS Evol Rear Shock Losing Air Pressure- Mtbr.com
Results 1 to 2 of 2
    Nov 2006
    Started my ride today at 225 psi and when i got home and took my bike off my rack about 4 hours later I noticed the rear end felt soft. So I checked it and it was down to 105 psi.
    It has to be either the air sleeve or the schrader valve right? If I do an air sleeve rebuild on it and replace the valve I figure I should be good to go or am I missing another possible cause?
    Thanks.
    ejh
    ejh is offline
    check the tube that the schrader valve screws there is a small "o" ring that might be leaking. try spraying it with Windex and look for really fine bubbles
  1. Replies: 9
    Last Post: 05-24-2018, 05:09 PM
  2. Replies: 1
    Last Post: 08-25-2017, 06:11 AM
  3. Replies: 9
    Last Post: 06-12-2017, 06:37 AM
  4. upgrade fox RP23 to fox factory DPS EVOL rear shock?
    By Picard in forum Shocks and Suspension
    Last Post: 12-26-2016, 08:25 AM
  5. New Fox Float EVOL DPS losing pressure
    By 007 in forum Shocks and Suspension
    Last Post: 06-16-2016, 08:30 PM
