Fox float 29er bits fit into float 26er??- Mtbr.com
Results 1 to 2 of 2
    Feb 2012
    may be a strange question but its worth a shot,
    I have a brand new never fitted 29er fox float 32 rlc 100mm with kashima coating and 9mm dropouts that I got for a project that isn't going to happen, I'm also building up a 4x bike and have a fox 26er float 32 rl 140mm with 15mm qr and would like to use the kashima stanchions and fit damper from the 29er in the 26er lowers
    is this likely to work, i've no problem taking them both to bits if its going to work but don't want to waste time if its not going to work
    they both seem to be the same overall length axel to crown so I'm hoping it will be a case of undoing the crush washers at the bottom of both forks, draining the oil, swapping the float springs and swapping the lowers over
    MTBR Member
    Reputation: shopcat_cycles's Avatar
    Maybe a call to Fox would be the best solution.
