Fox Fit4 Fork - What is the numbered dial on the axle? (Pic attached)- Mtbr.com
    Reputation: Arebee's Avatar
    Sep 2012
    What are the numbers for? I couldn't find anything in their manuals online.
    AreBee
    Reputation: Timothy G. Parrish's Avatar
    Apr 2014
    Quote Originally Posted by Arebee View Post
    It's used to adjust the location of the axle quick release handle on the other side of the axle. For example, if you tighten the axle and the handle is pointing down at the ground, you should adjust it so it points up and is within an inch or so from the front of the fork lowers. I'm not sure if I can explain it better, but that's what it's for.
    Apr 2014
    Scroll down about 3/4 of the page:
    https://www.ridefox.com/fox_tech_cen...onsQR32mm.html
    Sep 2012
    Ahhhhhhh! Thank you!
    I was on a different page.
    https://www.ridefox.com/fox17/help.php?m=bike&id=551
    AreBee
  1. Replies: 3
    Last Post: 08-13-2019, 02:33 AM
  2. Odd numbered 104bcd front rings
    By Ross1200 in forum Singlespeed
    Last Post: 10-03-2018, 01:38 AM
  3. Fox 32 Float RL Fork, right side numbered indents??
    By armoredsaint in forum Shocks and Suspension
    Last Post: 08-29-2012, 04:45 AM
  4. Avid Speed Dial 7 vs Speed Dial Ti
    By Call_me_Clyde in forum Brake Time
    Last Post: 01-14-2011, 03:03 AM
  5. Numbered or lettered SRAM shifters with Shimano RD
    By jrm in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 07-14-2004, 07:10 AM
Members who have read this thread: 27
