Fox Evol Re-aktiv and Fox 36 29er ... how many spacers installed by default?- Mtbr.com
Results 1 to 5 of 5
    So I have 2016 Trek Remedy 29er in Carbon with a 2016 Fox 36 150mm 29er fork. Curious if anyone knows how many volume spacers are in the fork by default? And likewise for the Re-aktiv shock?
    Mar 2012
    My 140mm 34 had 2 tokens. However, Fox's site states 2016 36s come with one blue spacer installed. Screw the spacers and get the MRP ramp cartage instead, it's more tunable and provides a better feel overall.
    The rear shock doesn't have any spacers from the factory. You can get the kit for ~$30 that has 5 different sizes, though the Reaktiv can only fit the smallest 3. I've got the largest that will fit and am toying with adding the smallest with it.
    Quote Originally Posted by jselwyn View Post
    MRP ramp control is not compatible with the 36.
    Mar 2012
    Quote Originally Posted by Rick Draper View Post
    Not yet, but it's on the way.
    Thanks for the info!
  1. Replies: 10
    Last Post: 05-24-2017, 05:55 AM
  2. 2016 Mach 6 - Spacers in EVOL Shock?
    By Markiel in forum Pivot Cycles
    Last Post: 10-11-2016, 01:22 PM
  3. Replies: 1
    Last Post: 06-08-2016, 09:39 AM
  4. Help! I installed my 15mm spacers backwards on my Flow EX's
    By homeless junkie in forum Wheels and Tires
    Last Post: 05-13-2013, 05:41 PM
  5. Should drivers be liable by default?
    By mtbxplorer in forum Commuting
    Last Post: 04-18-2013, 07:53 PM
