Fox DHX air 5.0 Will only extend about halfway.- Mtbr.com
Results 1 to 5 of 5
    JeffcoHo
    Reputation: JeffcoHo's Avatar
    Time for a rebuild or is there a simple solution?
    ‎"Reject your sense of injury and the injury itself disappears." -Marcus Aurelius
    Quote Originally Posted by JeffcoHo
    Release all the air and re-inflate. Still no good pull the air / re-install can then re-inflate.
    Biking Like Crazy!
    Reputation: blcman's Avatar
    stuck down!
    Becareful while unscrewing the air can. It might have some high negative air pressure built up in it!
    Put a screwdriver wrapped with a towel in the bottom eyelet to "catch" the air can IF it blows off.
    Put some ear plugs also!
    JeffcoHo
    After looking around for how to get the air can off I found this
    http://www.foxracingshox.com/fox_tec...aintenance.htm
    I am pretty sure its stuck down.
    Well Its a good excuse to buy a strap wrench.
    Biking Like Crazy!
    [B
    Well Its a good excuse to buy a strap wrench[/B].
    Just use channel lock plyers and a rag!
    Hard to get it started but then easy!
