Fox DHX 4 shaft bushing play- Mtbr.com
Results 1 to 3 of 3
    Sep 2019
    New question here. Fox DHX 4 shaft bushing play
    Ive deceided to rebuild an old DHX Ive found in my garage, I ordered new shaft (since the old one was scratched really bad) and when I was assembling the whole thing together, Ive noticed that there is fair amount of play between the shaft and sealhead assembly, Ive checked the inner shaft bushing, but it has only two minor scratches (possibly from old scratched shatf), so my question is, if this little play is normal for this old shock or I need to swap that inner bushing.
    Is this 1/2 or 15.75 mm? The piston glide ring is the other load bearing part so I would replace that first as its easier and also prone to wear. They come in the service kit if you can get one
    There will always be a small amount of play but too much is bad for sure
    Sep 2019
    When I pump the IFP reservoair it seems to leak oil onto shaft so I will definetly try replacing that main seal.
    Edit* It is 1/2".
  1. 2015 Fox 36 RC2 Bushing Play, Who Else Has It?
    By Yody in forum Shocks and Suspension
    Last Post: 12-15-2014, 01:03 PM
  2. Does your Fox 36 do this? Bushing play...
    By Thimk in forum Shocks and Suspension
    Last Post: 06-14-2013, 03:52 PM
  3. Bushing Fox 40 play
    By raph11 in forum Shocks and Suspension
    Last Post: 05-30-2013, 03:24 AM
  4. Oil leak or normal? New Fox DHX 4 leaving oil on the shaft
    By scocra in forum Shocks and Suspension
    Last Post: 07-02-2012, 10:44 AM
  5. Replies: 8
    Last Post: 06-16-2007, 03:12 AM
Members who have read this thread: 15
