Fox 36 Performance vs Performance Elite?- Mtbr.com
Results 1 to 28 of 28
    Jun 2017
    Can anyone tell me the difference? The googles doesn't seem to have anything. Are these actually the same fork, just some sites are lazy and don't put elite? Weighing my options on a new bike and im looking for the pros/cons between the two (if they are in fact different)
    Reputation: hikerdave's Avatar
    Mar 2006
    Quote Originally Posted by arm121 View Post
    The information you seek is on this site:
    Explore 36 Bike Forks | FOX
    In the Fox 36 the "Performance Elite" model is like the "Factory" with anodized black instead of Kashima coating, which I assume reduces the cost a bit.
    "Thank you, God, for letting me have another day"
    The Milagro Beanfield War
    Jun 2017
    duh I looked at that page shortly after posting this and apparently didn't read much past the first page.....
    Where is the "performance" model though? For example. The Yeti SB5.5 is equipped with "Fox 36 Performance 160" and the new SC HighTower LT has a "Fox 36 Performance Elite"
    ...not seeing a standard "performance" model on Fox's webpage.
    edit - Ok, it looks like the performance elite is the 2018 fork. Performance is "older" and has the Fit GRIP, where as now Fox only offers the Factory and Performance Elite with the FIT 4 damper
    May 2014
    Nope. They have both factory, performance elite and performance. Performance is OEM only, and has the GRIP damper which is said to be pretty darn good.
    Jun 2017
    i guess my issue with performance is that is has no LSC adjustment (at least from what i've gathered. It simply has a 3 position switch at the top of the fork and the GRIP knob at the bottom. I like how performance elite is essentially a factory fork without the Kashima Coat.
    That being said, why doesn't fox have info on the Performance model on their site?
    Dec 2008
    The GRIP switch actually works in between the three indexed positions too, so it has quite decent adjustability.
    Reputation: Mad.Mtb's Avatar
    Aug 2014
    Since the Performance fork is OEM, it doesn't have an information page on the Fox site. But their 2018 Performance model does have LSC adjustments. See this page in the Fox help center.
    I'm curious if others find upgrading to the Factory or Elite series worth the extra dough.
    The only trace I leave behind is tire marks.
    Quote Originally Posted by Mad Reptilian View Post
    That's a misprint. The performance/GRIP forks only have the 3 position HSC dial (with micro adjust in between).
    There are two flavors of dampers on the factory forks. Those being FIT4 and HSC/LSC. Both allow good LSC adjustability. To my knowledge, all of the performance elite forks have the FIT4 damper though.
    LCW
    LCW is offline
    Reputation: LCW's Avatar
    I have the Performance Elite 36 because I wanted the black stanchions, but every else is the same as Factory. FIT4 damper. The 2018 is absolutely an amazing fork.
    Santa Cruz Hightower LT
    Santa Cruz Tallboy 4
    Jun 2017
    Well I finally got my Yeti a couple weeks back and it has the Performance 36 on it. I was worried about the fit GRIP damper and was a bit disappointed that Yeti doesn't have an option for the Performance Elite for the LSC settings. To my surprise though, the Performance fork with the GRIP damper is great. I like the modulation between the 3 main settings (open, medium and firm) and its great to be able to adjust easily on the fly. I could through in a new damper if i wanted down the road, but i think this fork does a pretty good job how it is.
    Sep 2018
    What's the difference between the two - 36 Performance & 36 Performance Elite?
    The V3 Bronson S Build that im interested comes with 36 Performance version and i cant find any info about it... how these two compare?
    Dec 2008
    Quote Originally Posted by Muddy-Runs View Post
    Identical except for the damper - the Elite version has the Grip2 damper while the non-Elite has the original Grip damper.
    Aug 2017
    I have the Factory Fox 36 Grip2. I'm missing the lever climbing big hills like I had on my Pike. The LBS has offered to put the Grip on my bike so I have the lever. Will I lose any small bump etc. by swapping? I'm running 105psi, zero tokens, HSR LSR are both full slow and LSC and HSC are full open.
    Aug 2013
    Quote Originally Posted by BigART View Post
    That would be going from the best damper to the worst. If you do downgrade because you want a climb switch at least get a FIT4 with LSC adjust.
    I cannot believe that combination of damper settings would work for anyone ever on any bike or any terrain.
    Aug 2017
    Quote Originally Posted by PhillipJ View Post
    Iím surely using the wrong term for the compression.
    I was thinking FIT4 would be the better option, but I havenít seen it for sale. Only Grip2. Havenít looked that hard yet
    Aug 2017
    I can't find the FIT 4, just Grip 2. My wife's new bike is coming with a Fox 36 Performance (non elite) and a DPX2 Performance (non elite). I would like to upgrade hers to the Fit 4, it will have the Grip 1 on it.
    May 2014
    I would not spend a dime on changing the damper from GRIP to Fit4. I've been running the GRIP (1) for a bit less than a year now, and I love it. Far better than my old Fox 36 RC2 (2015). It's even got the lockout that appears to be important to you.
    Instagram: "lubbduro"
    Aug 2017
    Quote Originally Posted by lubb1 View Post
    Thanks! That will save me a lot of money.
    Reputation: rynomx785's Avatar
    Jul 2018
    I have a Performance 36 and I have been debating whether or not to upgrade to the Grip2 damper. I am curious if the Grip2 damper would give me the ability to open both the high and low speed compression circuits more (softer) than the open position on the regular Grip?
    Does anyone know the actual weight of the Fox 36 Performance (not Elite) forks?
    If everything other than the damper is the same then all three models (Factory, Elite, Performance) should be close to the same weight, right?
    May 2019
    Does anyone know the MSRP of the 2019 Fox 36 Performance version not the Elite version?
    Jul 2018
    Quote Originally Posted by jperozo View Post
    You can't buy the Performance model. It is OEM only.
    May 2019
    Thank you rynomx785...
    Yes, I know that is OEM that why I'm asking I can't find the price anywhere for the 27" version but I did find the 29" Performance version price. I have a "brand new" pulled from 2019 SC Bronson, never ridden that I want to sell
    May 2019
    Quote Originally Posted by rynomx785 View Post
    Yes, I know that is OEM that why I'm asking, I can't find the price anywhere for the 27" version but I did find the 29" Performance version price. I have a "brand new" pulled from 2019 SC Bronson, never ridden that I want to sell
    Jul 2018
    There is no MSRP on it though because it can't be purchased. Most of them that I have seen are right around $400 if they are in good shape.
    Sep 2018
    On the Fox 36 Performance (with Grip1 damper), between the Open-Meduim-Firm modes there are few more klicks (5 or 6), this modes plus the extra klicks controlling HSC, LSC, or combination of both?
    Jul 2018
    A combination of both.
  1. Replies: 2
    Last Post: 11-09-2018, 08:51 PM
  2. 2009 SJ Elite or 2011 SJ elite?
    By digthemlows in forum Specialized
    Last Post: 08-04-2012, 03:12 PM
  3. 2012 Superfly elite or Superfly 100 elite?
    By EricAlmighty in forum Trek
    Last Post: 12-05-2011, 08:58 AM
  4. Replies: 35
    Last Post: 08-05-2011, 08:29 PM
  5. 2011 Camber elite vs 2010 Stumpjumper elite
    By wsuwilliestyle in forum Specialized
    Last Post: 05-25-2011, 01:28 PM
Members who have read this thread: 143
