FOX 32SC Factory vs Performance vs Rockshox SID 29"- Mtbr.com
Results 1 to 31 of 31
    Aug 2017
    The Rockshox SID Worldcup weighs in @ 1587g with remote lockout and switch. I've heard the Fox 32 SC Factory is roughly 1380g but is that with remote and switch? Is the Performance heavier?
    Also has anyone here tried all three forks? I'm trying to figure out which one to choose
    Jan 2018
    Quote Originally Posted by Krisbin View Post
    I just made that decision and went with the Factory, mostly because surprisingly the Performance weighs more than a one half of a pound more (Fox Web Page) There is more adjustability on the Factory and there is a claimed better internals. Thanks to my builder, the increase was easy do deal with. Because I went with titanium instead of carbon, I am watching my weights a bit close. Went with a Project 321 Hub instead of an Onyx because they weigh like a very fat pig. Safe Travels.
    Aug 2017
    Quote Originally Posted by Emdexpress View Post
    Yeah that's what I feared I will most likely be the Factory
    Jun 2014
    The new SID with charger damper is a better performing fork, no idea about weight. How much do you weigh and what have you ridden previously OOC?
    Aug 2017
    Quote Originally Posted by Back2MTB View Post
    I'm 170 but the bike will be used for longer trips and needs to be as light as possible but obviously I also want well performing fork :-)
    My prior bikes have had Manitou Black, Manitou Minute and Lefty 2.0. Both the Manitous worked really well. I love the precision of the the Lefty but it may be to aggressive for longer trips.
    Jan 2018
    I check in at 215. I have ridden several but I never pushed one hard. I bought the very first SID in 1988 on a 8900 Trek with Hayes disc brake. Still have that horse. Rebuilt it numerous times. It lack at lot of rigidity but worked well enough and still does (with maintance). Only the very top of the line SID was considered on my build but 1500 USD did not quite fit my budget. Not using a current model, I cannot comment with knowledge about how they well they work.
    Jan 2018
    Rock Shock will replace the steering tube on their forks if you want your new ride to have a higher tube. Trek will not send a Project One bike out without cutting the steering tube to fit their specs. So there is that.
    Reputation: The Boz's Avatar
    Even the Rock Shox World Cup is heavier than the Fox 32 SC, but the Rock Shox can accommodate a much wider tire, if that means anything to you.
    Jan 2018
    When researching my build, I wrote down in notes that the Fox 32SC Factory weighed 1379 and the Performance model was over 1/2 pound more. I must say that while looking up something lose, I was not able to confirme the weight of the Performance. I hate bad info so please be advised. Sorry! I am still looking to confirmed. Seems pretty high.
    Aug 2017
    [QUOTE=Emdexpress;13549471]When researching my build, I wrote down in notes that the Fox 32SC Factory weighed 1379 and the Performance model was over 1/2 pound more. I must say that while looking up something lose, I was not able to confirme the weight of the Performance. I hate bad info so please be advised. Sorry! I am still looking to confirmed. Seems pretty high.[/
    Does 1379g include remote and switch and 29"
    Elitest thrill junkie
    Reputation: Jayem's Avatar
    How do you figure? They both use similar bladder-damper technology with shimmed rebound and compression pistons, with a "quick range" adjuster and low-speed compression adjust. They are literally a lot more similar than different. Fox was able to shave a bunch of weight without using carbon, impressive. I've had 2 charger-damper forks and I have the 32 sc factory on my XC rig. The charger is not a better performing damper.
    Jan 2018
    based on a review I saw with the Factory sitting on a scale, no remote or switch near the scale and was aprxoximatly 1379. I have not seen the weight of the remotes posted anywhere. I plan on reaching down and flip the dial on the move. Plan to anyway. Seems like weight that is not needed, or so I think so.
    Aug 2017
    Reputation: Lone Rager's Avatar
    Dec 2013
    I'm wondering how they fit 1/2 lb more weight into the Performance version. Where are the weights on the Fox website?
    What, me worry?
    Quote Originally Posted by Lone Rager View Post
    When comparing the weights, make sure you are comparing the 32 SC Performance and not the regular 32 that Fox still sells just to make things complicated when researching.
    Also, the 32 SC Factory comes with the Kabolt thru-axle which saves some weight and the 32 SC Performance does not.
    Quote Originally Posted by The Boz View Post
    I would think if you're buying a SC fork for the weight, you aren't running a bigger heavier tire.
    Ripley LS v3
    OG Ripley v2 handed down to son
    Jan 2018
    Error as previously stated. Thanks!
    Everyone would prefer the lightest weight. Your terrain has an impact on what width tire and rim will give you the best overall performance. More of a trail bike a 2.6 tire may be a future choice and the SID would take it.
    Reputation: JoePAz's Avatar
    May 2012
    I have Fox Factory 32 SC 15x100 with Kabolt. No remote and cut steer tube. 1377 grams on my home scale.
    Joe
    '18 Specialized Epic 29", 19' Vassago Optimus Ti SS 29", '19 Ibis Ripmo, XC, AM, blah blah blah.. I just ride.
    Reputation: coke's Avatar
    This site is a good place to check for weights. They have scale shots of a lot of products.
    https://r2-bike.com/ROCK-SHOX-Suspen...T-tapered-2018
    https://r2-bike.com/FOX-Suspensionfo...-tapered-51-mm
    Quote Originally Posted by eb1888 View Post
    What trail bike would you run 100mm fork on?
    Ripley LS v3
    Jan 2018
    Rechecked weight between Fox 32 SC Boost Factory vs Performance.
    Factory = 1353 vs Performance = 1780 Wow!
    Performance is a mind blowing 427 grams heavier. 1 pound = 454.4 grams so the Performance is 27 grams short of a pound. Sounds wrong and I have not weighed them but it seems those are the numbers reported by some that have the product in their hands. Mostly there is not much performance difference between the two shocks imho. But the weight deal makes it real easy to pick for me.
    Jan 2018
    Some of the differences of reported weights of the Factory (not much however) may be if the two supplied spacers have been removed or two additional ones added. In addition, the steering tubes may have not been cut or cut to different lengths. Still the Proformance weighs like an overfed hog.
    Mar 2015
    It is advertised as being that much heavier, but it is not that much heavier. Adding the Kabolt through axle brings the weights within about 100G.
    Mira estos:
    https://esmtb.com/fox-32-stepcast-fa...e-peso-precio/
    expect remote to be roughly 135 ish. I love my twin loc
    Jan 2018
    Nice post. If I could remember more from school, the article may say if the steering tubes were cut and to what length. 100 grams is about 1/4 pound. Heavier but not as much as claimed. Must want to sell more Factory units. Worked on me.
    Mar 2015
    75 gram difference between forks
    Kabolt cost 45 dollars and makes a big weight difference:
    41 between bolts.
    116g total difference which is almost exactly 1/4 pounds.
    I found this article and these pictures when I was trying to sort out the weight gain between the F34 and the Performance stepcast. Fox would have you believe that these forks weigh almost the same. Sadly, I would gain a bit of a weight penalty t put on the F 34 120mm.
    I just called up Fox and asked.
    Ripley LS v3
    This was an older performance Float 100 that I had, but this shows some of the differences. They really went to extreme ends to shave weight from the SC and not use carbon, streamlining the crown, making it narrower, the lowers, and so on. The SC was with an uncut steerer at this point I believe.
    FOX 32SC Factory vs Performance vs Rockshox SID 29"-01ad7305a0485c5e79fdc014a31fe50281d7768159.jpg
    FOX 32SC Factory vs Performance vs Rockshox SID 29"-01a69785939e05f9ae6bf86d49bb036e2b98f5446a.jpg
    FOX 32SC Factory vs Performance vs Rockshox SID 29"-0112c632b13926e76e92d524fab963184de1d3e483.jpg
    The real choice IMO is the 34 or 32. If you are considering a 32 SC because you do XC racing and want a lightweight platform, it's a great fork for this. If you want a trail-capable fork, then deciding between the standard 32 or the 34 is much more difficult IMO, the 34 is really only slightly lighter and much beefier and capable of more travel. The 34 is a better 120mm platform IMO. It won't give you the feathery-light-weight, but it's a better match for the ~120mm rear travel bikes IMO and if you want to over-fork your XC bike a bit. For XC racing, the 32 SC is sweet.
    Dec 2011
    I just swapped my Factory SC 32 to another bike but needed a new CSU as it had been cut too short. We couldn't get the Kashima factory one so just got the black performance version.
    They weighed the same (accounting for slightly longer steerer in new one). Performance feels identical, I'm sure the kashima coat works slightly better but I suspect its more marketing than performance.
    2019 Trance 29
    2018 Epic
    Procaliber- sold
    ASR-C- sold
    ARC Carbon- sold
    SB-95C- play bike- sold
    Reputation: Pedalon2018's Avatar
    Apr 2018
    Quote Originally Posted by m3bas View Post
    The coating may look nice to some but I could not tell any difference between the Factory vs Performance. I went Factory because of weight with little increase in the cost. Rockshock will replace the steerer tube on their forks while Fox not so much. But I much perfer metal tubes over carbon, mostly cause inspections require fork removal and my inherent caution on critical parts. While not a big deal, during riding season I tend not to do that.
    Quote Originally Posted by TwoTone View Post
    Bike packing. Big tire's have benefits in varied conditions.
  1. Replies: 2
    Last Post: 11-09-2018, 08:51 PM
  2. Rockshox SID RCT3 vs. Fox 32 Float Performance
    By prj71 in forum Shocks and Suspension
    Last Post: 06-22-2017, 01:12 PM
  3. Fox 32sc Rebound Knob (removable?)
    By Lelandjt in forum XC Racing and Training
    Last Post: 06-12-2017, 10:35 PM
  4. Deleted
    By Lelandjt in forum Vacations & Destinations
    Last Post: 06-11-2017, 11:06 PM
  5. Replies: 21
    Last Post: 03-17-2016, 07:53 PM
Members who have read this thread: 59
