Fork Identification- Mtbr.com
Results 1 to 12 of 12
    Fork Identification
    I have a fork that I need help identifying so that I can find the manual and perform an overhaul to it.
    I believe it is a 2001 or 2002 SID Race (it has the race sticker but no other identifying labels).
    From the rider's perspective:
    The left leg has a positive air valve on the top and a negative air valve at the bottom.
    The right leg has an air valve at the top with a sticker indicating its the Pure DeLite system 20 - 60 psi. The bottom of the right leg is the rebound adjustment.
    Both air valves at the top have a plastic cap that screws into the top cap to keep the valves clean - black in color with a rubber o-ring for sealing.
    It has both v-brake and disc brake mounts - the crown is scalloped where the uppers are inserted.
    Thanks.
    Pictures.
    pictures
    pictures attached
    Looks like a second generation SID.
    Quote Originally Posted by bad mechanic
    In which case what manual should I look for? What year is 'Second Generation'?
    Reputation: cort's Avatar
    Ohhh, I want to play!
    I'm guessing 2001-2002. (Will check my little "black book" at work to confirm)
    Quote Originally Posted by cort
    thanks for playing!! I am trying to figure this out so I can find the right manual to do a rebuild with...
    This should be the manual you need:
    http://www.sram.com/_media/techdocs/...ce%20Guide.pdf
    awesome thanks. I couldn't seem to find this on sram's site - I guess because I am fairly certain the fork is not an '03.
    B A N N E D
    Here's some more Service & Owners Manuals you can look at: http://manualer.happymtb.org/rock%20shox/
    Quote Originally Posted by cobba
    this is where i had been looking based on the sticky - just wasn't sure which one was the right one.
    Quote Originally Posted by jbsmith
    Your fork is an 03-05 SID. The easiest way to distinguish is the arch. The SID generations are:
    98-02 - 1st generation
    03-08 - 2nd generation
    09 - 3rd generation
    Within a generation, aside from incremental improvements, really the only changes you saw were in the damping system. The 2gen SIDs used Pure damping, with the SID Team and WC received Motion Control damping in 06.
    A great resource to help identify parts is:
    http://www.togoparts.com
