Finally received my Redshift ShockStop Suspension Seatpost- Mtbr.com
Results 1 to 9 of 9
    Reputation: wgscott's Avatar
    Jul 2013
    I pre-ordered/Kickstarted this in April 2018 (at the SeaOtter). It took awhile, as they refined the design and addressed some issues, but it finally got here last night. I'm planning to use this on my Advocate Seldom Seen steel drop-bar hard-tail mountain/trekking bike. (Build thread here.)
    It comes in one size fits roadbikes, so I also ordered a shim.
    Attached Thumbnails Attached Thumbnails Finally received my Redshift ShockStop Suspension Seatpost-img_0995.jpg
    Underskilled
    Reputation: CaveGiant's Avatar
    Interested for a road bike commute over appaling roads. Does it pedal well?
    Jul 2013
    I haven't had a chance to put it on the bike yet. I'll let you know. The pre-load is fully adjustable, so you can make it as stiff as you need to.
    This place needs an enema
    Reputation: mikesee's Avatar
    Aug 2003
    Cool. Check back in once you've ridden it.
    I've got a few years on a Bodyfloat with no complaints, but am always open to improvements.
    Jul 2013
    One step closer: Installation and pre-load set up for 20% sag.
    (The Redshift stem is primarily for use in conjunction with the rigid fork that came with the frame. I got the Manitou Machete for $156 on Chain Rxn btw.)
    Attached Thumbnails Attached Thumbnails Finally received my Redshift ShockStop Suspension Seatpost-img_0997.jpg
    Jul 2013
    Well, it isn't love at first ride. It moves a lot, even riding on a smooth surface. Looking at their videos, I think this is by design, but I find the sensation a bit disconcerting. I will now crank up the pre-load some more (as if I were 40 lbs heavier) and take it from there. (I suspect I just need to get used to it. I have a tendency to hate anything new.)
    Edit: Cranking up the pre-load helps a lot.
    May contain nuts
    Reputation: Haggis's Avatar
    Id quite like to try a Redshift stem on my rigid
    Jul 2013
    Quote Originally Posted by Haggis View Post
    The stem is great. I highly recommended it. The only downside is the weight, but it weighs a lot less than any suspension fork, including the Lauf. (I also happen to think it works a lot better than the Lauf.)
    I think I will probably wind up liking the seatpost too.
    Jul 2013
    I gave the seatpost a good long test ride today, with lots of ruts and washboard and stuff. It really works quite well. I also did a hard climb with it, and the penalty was fairly minimal (I had a couple of PR segments in the climb, so it couldn't have been too much of a handicap.)
    So despite my previous skepticism, I think I can endorse this. I've never used a quality suspension seatpost before, so I can't compare it to others.
    It definitely won't magically convert a hardtail into a full suspension bike, but it will make riding rough stuff rather more pleasant.
  1. ShockStop Seapost - Just sharing.
    By j102 in forum General Discussion
    Last Post: 11-29-2018, 10:03 AM
  2. shockstop suspension stem on rigid 29er?
    By Jumbotron in forum 29er Components
    Last Post: 10-30-2018, 04:50 AM
  3. Just received my Poc Trabec Race
    By hanklr in forum Apparel and Protection
    Last Post: 06-22-2013, 11:56 AM
  4. Received my Fly Ti Frame today
    By rdickens48 in forum Motobecane
    Last Post: 10-14-2012, 11:19 AM
Members who have read this thread: 113
