Do new forks come with star nut??- Mtbr.com
Results 1 to 7 of 7
    This may sound like a dumb question, but do new forks come with the star nut (star-fangled nut) for the head set to attach to the steer tube? I'm about to order a new RS Reba Race and want ensure that I order everything that I will need for the install. Thanks...
    a e i o u and sometimes y
    Reputation: Brizn's Avatar
    Mar 2006
    Typically forks do not come with a star nut. New headsets do, though. Your LBS should have a new star nut for you to shove in there.
    Reputation: lonbalz's Avatar
    Check your local LBS for a star nut. Every fork I've ever bought has never come with one. They should have one and often times if you do much business with them, they will put it in for you too free of charge.
    Reputation: switch55's Avatar
    Feb 2006
    You will also most likely need the shop to cut the steerer tube to the correct length for your frame. They can also then put in the star nut.
    Jan 2011
    HELP! im swaping my fox 40 2008 for some 2010 boxxers. will the star nut i have fit those forks?
    Feb 2010
    Star nuts typically are only good for one use. You'll mangle the old one trying to pull it out. Just go to a shop. They'll probably give you a new one for free.
    ~Disc~Golf~
    Reputation: highdelll's Avatar
    Quote Originally Posted by hasisno1
    only if you lower it to 178mm
    Honestly... ahh I give up
