Do the fox travel spacers fit in the Reba?- Mtbr.com
Results 1 to 3 of 3
    I'm wanting to decrease travel in my Reba from 115 to 100mm. I have a couple of fox spacers that would do the job (?). Would these spacers fit in my Reba? I have a 20 and 15mm spacer (float used to ride at 65mm but I brought it back up to 100mm).
    If it doesn't work I will try to get my LBS to give me one from the parts bin. Thanks!!
    The spacers aren't anything special. I think the diameter of the rod they go around is about 10mm. If the fox ones fit, I think they will be fine. I have improvised this using a skateboard bushing and it worked fine. You can cut spacers to a specified size as well.
    This may impact your warranty?
    Reputation: kirbster1966's Avatar
    If you need a rockshox one, let me know. I have a few lying around. You pay postage and you can have one. Likely $2.
    Ask me About O Rings (Check the Classified section)
