DHX Coil vs. Air?- Mtbr.com
Results 1 to 2 of 2
    Reputation: Mountainbikextremist's Avatar
    Jan 2005
    New question here. DHX Coil vs. Air?
    I'm currently torn between the DHX Coil and Air. I am leaning towards the coil though. I do heavy trail riding, jumping, and drops no larger than 5 ft. I do plan to progress bigger though. And i dont mind the extra Ib. I am currently riding an 05 Kona Coiler. What would you get?
    If I want your opinion, I will give give it to you...
    You got like 3 feet of air that time... -Napoleon Dynamite
    Elitest thrill junkie
    Reputation: Jayem's Avatar
    Do a search, there's some good discussions on the subject.
    In a nutshell;
    On the same bike, I liked the DHX-C much better. It was much more consistant and use it's travel much better. With the same settings, the DHX-A blew through the travel and felt kind of crappy at higher speed when bumps would over-compress the damper and it would have little travel left for the next bump. The DHX-C would not do this, in fact I can run 33-40% sag on the DHX-C and not worry about bottoming and it still uses the travel very well. I can't make the DHX-A do this, it just blows through the travel and does what I described above. The slow to medium-speed performance of the DHX-A is very good, seems better than the DHX-C, but this is because it's blowing through the travel and using an excessive amount of stroke for bumps. The DHX-C is much more "consistant" in one word, and I have removed the DHX-A and will not be using it in any forseeable future circumstances.
