Crush Washer on Pike Damper Side Bolt- Mtbr.com
Results 1 to 5 of 5
    Mar 2006
    Name:  Screen Shot 2014-01-09 at 12.45.34 PM.png
    Anyone know how to get the crush washer off from the base of the threads of this bolt on the Pike?
    Reputation: tomacropod's Avatar
    With a small sharp thing? The guy in the photo has the right idea. Unless it's leaking and you need to replace it, there's no need to remove it.
    - Joel
    Cycling is Serious Business.
    Reputation: trailbildr's Avatar
    Dec 2004
    The black crush washer? Just grab it with pliers. And always replace them. They are designed to deform a bit so when you take one off, you are asking for leakage. It's not guaranteed to leak, but not worth the risk to save a dime. Manual says replace.
    mk
    TrailWerks Cyclery
    TrailWerks Suspension Service
    trailwerkssuspension.com
    trailwerkscyclery.com
    Mar 2006
    It appears that there is a little recess/gland that it sits in and the washer gets pressed flat into it so you can't get any purchase. The pokey thing sounds like the best bet, but I have a penchant for stabbing myself.
    After about 5 hours of riding there doesn't appear to be any leakage from using the old one, but, normally, I'm with trailbildr in that I always replace them when I pull the lowers.
    Dec 2004
    Just go Mythbusters on it and use some C4.
    mk
    TrailWerks Cyclery
  1. Fox Fork Crush Washer Sizes
    By sancycling in forum Shocks and Suspension
    Last Post: 08-11-2013, 10:59 AM
  2. Hollowgram fixing bolt washer?
    By Om Flyer in forum Cannondale
    Last Post: 03-02-2013, 06:56 AM
  3. X9 Rear Derailleur Hanger bolt outer washer question w/ Pic
    By F2a in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 08-30-2012, 10:21 AM
  4. DUC 32 damper knob/damper rod bolt turning
    By voob in forum Maverick
    Last Post: 01-09-2012, 08:35 PM
  5. Fox Float RLC Oil Change Damper-Side/Spring-Side Oil Bath Help?
    By zbear in forum Shocks and Suspension
    Last Post: 09-18-2011, 07:06 PM
Members who have read this thread: 7
