converting to rigid fork....help....- Mtbr.com
Results 1 to 3 of 3
    Reputation: zippy895's Avatar
    2005 large sworks hardtail.i cant figure what size carbon fork i need .240,265,220mm,etc???
    90mm suspension fork was stock on this frame i believe.
    Reputation: cort's Avatar
    zippy895,
    Measure your old steering tube that came off your S-Works bike. If you don't have the fork, then measure the HT length + headset stack height + spacer(s) to determine the correct length you need to get.
    The Bubble Wrap Hysteria
    Reputation: mtnbiker4life's Avatar
    Do you mean steer tube length or Axle-2-Crown length?
