Coil Shock for Stroke Reduction- Mtbr.com
Results 1 to 2 of 2
    Mar 2011
    I'm considering picking up a second hand coil shock in 190x50mm to modify to a 184x44. Depending on the shock, all it may need is an additional 6mm 'topout' spacer on the shaft assuming that still leaves enough preload adjustment. Any problems with this logic? Anyone done similar?
    Currently looking at something like a fox van rc as they can be had fairly cheaply. Anything else I should consider?
    The Fastest of Bananas
    Reputation: FastBanana's Avatar
    Aug 2013
    Quote Originally Posted by balfa View Post
    Had it done on a DHX2. Worked fine.
    Sent from my SM-G975U using Tapatalk
  1. Replies: 29
    Last Post: 3 Weeks Ago, 06:54 PM
  2. Replies: 1
    Last Post: 01-20-2011, 11:06 PM
  3. Replies: 1
    Last Post: 04-04-2007, 03:15 PM
  4. 2" stroke Manitou spring on 2" stroke Manitou shock?
    By Enduro_506 in forum Shocks and Suspension
    Last Post: 05-05-2006, 02:23 PM
  5. using a 2.25" stroke shock on a frame intended for a 2"stroke?
    By ATOMICned in forum Shocks and Suspension
    Last Post: 04-08-2006, 04:30 AM
Members who have read this thread: 19
