This clunking noise (FOX 36)- Mtbr.com
Results 1 to 3 of 3
    Reputation: client_9's Avatar
    I have a 2015 Fox 36 rc2 that is making THIS NOISE.
    Someone says it's the Check Limiter on the rebound assembly.
    Part # 210-22-248 in THIS DIAGRAM
    Before I start tearing apart my rebound rod,
    I wanted to ask if anyone else has solved this mystery.
    ... and yes I've isolated the noise to the fork internals.
    and no, it's not slop in the bushings or a loose air volume spacer.
    - thanks for reading!
    It's the spring and shim above it that they will be referring too, the spring is occasionally too soft/not preloaded enough so it lags and knocks when changing direction. Add another shim for preload or carefully stretch out the spring and it should take care of it
    www.thesuspensionlab.nz
    Servicing in Rotorua, NZ/Vorsprung Elite Tuning Centre/DVO service centre/Insta @thesuspensionlab
    Quote Originally Posted by JohnnyC7 View Post
    This makes sense. It sounds like a spring.
    Thanks so much for replying!
  1. Float 36 knocking/clunking noise
    By ChainChain in forum Shocks and Suspension
    Last Post: 12-04-2018, 02:22 AM
  2. Fox DPS clunking noise
    By jeremy3220 in forum Shocks and Suspension
    Last Post: 03-12-2018, 07:35 PM
  3. Replies: 0
    Last Post: 09-20-2005, 10:11 AM
  4. Fox Talus shock and "clunking" noise?
    By dumper in forum Shocks and Suspension
    Last Post: 08-12-2004, 11:53 PM
  5. Fox V125 RLC making "clunking" noise...
    By Hecklerboy in forum Shocks and Suspension
    Last Post: 08-09-2004, 08:06 AM
Members who have read this thread: 35
