can't find tread to mod Fox RLC fork to get all of the 5.5" claimed- Mtbr.com
Results 1 to 10 of 10
    Reputation: biketuna's Avatar
    I've searched and I can't find the thread that explains how to do it.
    Does anyone remember where it is?
    _______________
    1x10 IS SO FINE on my 21.9 lbs IBIS SL-R
    11-36 XTR in the rear, 36T wide-narrow upfront
    Calm Like a Bomb
    Reputation: pipes10's Avatar
    which fork is this?
    '17 Hatchet Carbon
    '17 Troy Carbon
    '16 Django Carbon
    '16 Wilson
    '16 Farley 5
    https://www.instagram.com/jayparrington/
    arc
    arc is offline
    Sep 2004
    I think the thread started in the Ibis forum, check the early mojo posts, and then got cross-posted into the shock and suspension forum. Or you can try searching cut stanchion rod.
    The short story is to disassemble the air spring side of the fork, cut about 15mm off the stanchion rod, drill a new hole for the pin and reassemble the fork. This makes the air chamber bigger so air pressure doesn't ramp up as quick as you go deeper into travel.
    Reputation: spookyload's Avatar
    If you don't feel comfortable doing this yourself, PUSH does a high volume air when they rebuild shocks. I think it is $30 on top of a normal rebuild.
    pipes10 it's the fox float 32.
    Thanks everyone for the info, I'll keep searching.
    _______________
    Go SOLAR...
    Reputation: larlev's Avatar
    Did you find it? If you mean the air rod cutting mod I can get you the article.
    Bike Crusader~
    Jan 2009
    "Ride it, Feel it...."
    Thanks masnumata!!
    larlev is this the same one you have? Post it if it's a different one. Thanks!!
    _______________
    Go SOLAR...
    I aplogize man I had a copy of the australian MTB mag article where it was orginally published and now I can't find it. If you haven't tried yet...search "travel mod for Fox fork" and see if you can find the post that has a link.
    I have done this mod and the performance is night and day.
    Bike Crusader~
    Jan 2009
    Cheers mate, have fun with the tinkering!
    Mas
