Can I put a 550x2.35 spring on my Heckler?- Mtbr.com
Results 1 to 5 of 5
    I'm a newb when it comes to full suspensions but I have a Heckler that has the Fox DHX 5.0 rear shock on it with a 400x2.45 spring. It was supposed to come with a stiffer spring but the shop messed the order up, blah, blah, blah, etc... Anyway, my buddy has a 550x2.35 spring that he said he will give me but I am not sure if it will work. Can anyone help?
    I'm 280lbs if it helps.
    Mark Jones
    2009 Specialized Rockhopper Expert Disc 29
    Deadhead
    If it's a DHX spring it will work.
    "If you can get both wheels sliding with no brakes, that's when you really know that you're cookin." Nathan Rennie
    Reputation: ANdRewLIu6294's Avatar
    uh...
    ...the new spring has a shorter stroke, it might coil bind
    i would just get a new spring.
    Heckler's come w/ a 2.25" stroke shock so 2.35 will work as long as you don't go overboard on the spring preload. Some shock manufactures run spring strokes almost the same as the shock strokes.
    Jun 2005
    if its a 2.25 stroke shock, the 2.35 spring will work fine
