Can I Extend Fox 34 Step Cast 120mm to 130mm?- Mtbr.com
Results 1 to 10 of 10
    May 2018
    The Intense Sniper Trail Build comes with a Fox 34 Step Cast Float front shock 120mm. I read on the Fox website that it has 2 air spacers. It says that if your sag is set correctly and you are using all your travel you can add a spacer to regulate it from bottoming out. Or if your sag is set correctly and you are NOT using all your travel then you can remove a spacer. I was thinking the spacers related to the amount of travel. I was wondering if there is a way to change the travel of the shock from 120mm to 130mm. Is that possible? I thought the spacers had something to do with it, but I'm a little confused.
    Elitest thrill junkie
    Reputation: Jayem's Avatar
    Still no.
    Sep 2019
    Spacers you're referring to are air volume spacers that reduce the air volume in air chamber by making it smaller. Reducing air volume in air chamber doesn't physically increase travel since the air chamber is already longer than the travel of the fork. However, if sag (related to air pressure) and the force applied to the fork (related to the aggressiveness of riding) are the same, then the smaller air chamber results in less travel used due to added progressiveness from smaller air chamber size. Air is gas and gas doesn't compress linearly but the force required to compress increases exponentially the more you try to compress it.
    That being said, some forks also have travel adjust spacers in the air spring but generally I believe it's less common for a fox fork to have such installed in stock installation. To be sure, you could check from the fox service manual. Just need to input the four-digit tune code or serial number found from your fork in the fox service page for instructions.
    Reputation: jimarin's Avatar
    Mar 2005
    It is 100% certain that you can not go to 130 in a step cast. I looked into it before buying a 130 34.
    Sep 2019
    Quote Originally Posted by jimarin View Post
    I would take your word on it. I was just trying to offer a bit more in-depth explanation as OP was confused about the spacers.
    Still no.
    So...there's a chance?
    Quote Originally Posted by the mayor View Post
    Maybe
    Guerilla Gravity Shred Dogg
    Fezzari Signal Peak (For Sale)
    Pivot Shuttle (wife's)
    May 2018
    Quote Originally Posted by ErnoNykanen View Post
    Spacers you're referring to are air volume spacers that reduce the air volume in air chamber by making it smaller. Reducing air volume in air chamber doesn't physically increase travel since the air chamber is already longer than the travel of the fork. However, if sag (related to air pressure) and the force applied to the fork (related to the aggressiveness of riding) are the same, then the smaller air chamber results in less travel used due to added progressiveness from smaller air chamber size. Air is gas and gas doesn't compress linearly but the for required to compress increases exponentially the more you try to compress it.
    Thank you. That helps explain the air spacers. I guess Iíll be riding 120 for awhile. Very helpful.
    Nov 2014
    Sure, all you have to do is get the 130mm air shaft, swap out the CSU assembly, swap out the lowers, and swap out the damper. Voila! Your 34 SC is now a 130mm fork!
    Quote Originally Posted by dlxah View Post
    Sure, all you have to do is get the 130mm air shaft, swap out the CSU assembly, swap out the lowers, and swap out the damper. Voila! Your 34 SC is now a Fox 34 130mm fork!
    Fixed it for ya
  1. Using Twinlock with new Fox 34 Step Cast fork
    By MHCBH in forum Scott Sports
    Last Post: 02-11-2019, 05:04 AM
  2. 3.0 Dirt Wizard in a 34 Step Cast?
    By Feendog in forum Surly
    Last Post: 10-04-2018, 10:51 AM
  3. Fox 34 vs Fox 34 Step Cast
    By dinsum in forum Shocks and Suspension
    Last Post: 08-29-2018, 03:48 PM
  4. Removed cast, need to extend ligaments. Any help?
    By Daemon[CRO] in forum Rider Down, injuries and recovery
    Last Post: 10-03-2011, 08:05 AM
  5. Fox 130mm coil vs. Fox float 130mm vs. manitou Black air 120mm??
    By ROG30Y in forum Shocks and Suspension
    Last Post: 01-07-2006, 01:34 PM
Members who have read this thread: 50
