Best shock pump? Need recommedations.- Mtbr.com
    I've got a Fox Float rear and am getting a Reba front. What will work well and work for both shocks?
    Unchained Freewheel
    Reputation: Tarbaby4Ever's Avatar
    I would also like an answer to this q,as i have a Fox rear and plan on putting a Reba
    with U-Turn on a new Truth frame.
    The Trail Never Ends.
    Reputation: Jodiuh's Avatar
    I tried the $40 Topeak, but found the gauge a touch hard to read/dial in. I picked up a Marzocchi that's billed as low pressure @ 200 max psi. It reads much easier than the Topeak. If you're 200+ lbs, it might be an issue tho.
    Quote Originally Posted by 4nortons
    I liked the one that came with my '05 Reba, seems to loose the least amount of air during the disconnect of any stock pump i've used so far and it folds in half for easy storage in the camelbak or tool box. The only problem is the thread fitting on the scraeder end does unscrew every once in a while.
