Anyone swapped to a HV RP23 air sleeve and want to sell their old LV to me?- Mtbr.com
Results 1 to 11 of 11
    No, that's not phonetic
    Reputation: tscheezy's Avatar
    New question here. Anyone swapped to a HV RP23 air sleeve and want to sell their old LV to me?
    I am looking for a low volume sleeve that fits a 7.875" RP3 or RP23 or DHX Air (I don't think the stroke matters, but mine is 2.25 just FYI). I don't know if there are even many of these out there since it seems like most of the shocks shipping these days are already HV styles.
    My video techniques can be found in this thread.
    Bite Me.
    Reputation: cutthroat's Avatar
    I have a 7.5 LV sleeve from my RP3 - don't know if this would work or not.
    When I see an adult on a bicycle, I do not despair for the future of the human race. ~H.G. Wells
    Thanks, but it won't. I have a 7.5 LV sleeve also. The air can on the 7.875's are longer.
    So is your face
    Reputation: celluloid hero's Avatar
    PM sent.
    IT'S NOT THE FALL THAT HURTS. IT'S WHEN YOU HIT THE GROUND.
    Reputation: bjj4202000's Avatar
    Quote Originally Posted by tscheezy
    Would the AVA sleeve get you down to the volume you are looking for?
    Fo' Bidniz in da haus
    Reputation: FoShizzle's Avatar
    pretty sure i have one from my Float...would that work or is the RP23 different? I put the HV on my El Rey right when i got it but i know the LV is somewhere and you can certainly have it if you still need it (7.875 x 2.25 shock as you know)
    Reputation: jncarpenter's Avatar
    Why not just get one directly from Fox? I think I paid $35 for mine direct.
    Reputation: mcrumble69's Avatar
    Will the 7.875 x 2.25 LV can fit the 8.5 X 2.5 DHX Air?
    If so I'm also looking for one.
    MTB Monkey
    Reputation: Jefe74's Avatar
    Mar 2006
    To increase the compression ratio, just add a few CCs of Float Fluid to the main chamber.
    Quote Originally Posted by Jefe74
    Adding oil will only migrate to the negative chamber which will cause problems.
    half tread will travel
    i heard ur better off 2 put a couple of o rings in side the air spring 2 lower air volume...adjust as need d...
    tread lightly...earth is our playground
