Anyone with intimate knowledge of the PUSH pike rebound piston?- Mtbr.com
Results 1 to 14 of 14
    dressed to play
    Reputation: guitarhero's Avatar
    Should the nut on the end be nipped up?
    Reputation: PUSHIND's Avatar
    There is no bolt on the end.
    Darren
    Reputation: Vespasianus's Avatar
    Is that a Fox Fork?
    Elitest thrill junkie
    Reputation: Jayem's Avatar
    Quote Originally Posted by Vespasianus
    Is that a Fox Fork?
    Nope, RS. It's just Push's upgraded piston on the right.
    dressed to play
    Quote Originally Posted by PUSHIND
    Darren
    Sorry, i meant the nut that can be seen in the picture at the top of the rebound assembly.
    err, 27.5+
    Reputation: AL29er's Avatar
    Better question is when will the factory fork system be back online for us to order
    Quote Originally Posted by saturnine
    that's the stupidest idea this side of pinkbike.
    Looks like Tuesday of next week.
    Darren
    Quote Originally Posted by guitarhero
    I'd say yes if its job if to clamp down on the shim stack. I can't see a reason why it should be loose?
    And, PUSHIND, it's really sad that you apparently can't be bothered to answer someone's simple question about one of your products. Says a lot about you.
    EmanResu,
    There must be some kind of misunderstanding here. I think my participation on the boards is well documented in providing detailed information about all of the things that we do. I thought that I had answered the OP's question? I didn't realize the term "nipped up" meant tight. My bad.
    Darren
    Outcast
    Reputation: Renegade's Avatar
    This appears to be a simple miscommunication due to dialect differences. Or, if you brits learned how to speak proper english.....
    Nipped up? How did you guys come up with that?
    dressed to play
    it goes... loose > finger tight > nipped up > bastard tight > stripped
    Outcast
    Ah, thank you Guitar hero. You have expanded my brit vocabulary. Prior to this, the only terms I knew were buggered up, bugger off, and piss off.
    Okay, based on that...yes, it should be nipped up. The exact spec is 35in/lbs. We recommend that you clean the threads and apply a light drop of blue thread lock as well.
    Darren
    EmanResu,
    Darren
    Sorry, just seemed like you were being weird about it which I didn't understand as it seemed like an honest question.
