Air pressure- Mtbr.com
Results 1 to 3 of 3
Thread: Air pressure
    Air pressure
    Sorry if this seems newbish im finding it hard to find info. I have a 2005 manitou Nixon fork It says air pressure 65 to 85% body weight. now for me that would be about 220psi. Do i really want to put 220psi into this fork? or is there a max?
    Reputation: Vespasianus's Avatar
    An IT fork? Assume you weigh close to 260lbs?
    220 lbs of air should be fine but make sure you have the fork serviced professionally. The o-rings and internal seals on a 2005 fork may not be in the best shape.
    Use sag as your starting point, not the manufacturer's recommended air pressure.
  1. RS Dual Air vs Air U-Turn: which is more useful?
    By derailin_palin in forum Shocks and Suspension
    Last Post: 10-23-2009, 02:22 AM
  2. 5th element "no" air pressure in main chamber
    By x-man in forum Shocks and Suspension
    Last Post: 08-29-2006, 03:32 PM
  3. new 05 stink, ?'s on how forks work
    By cobra in forum Shocks and Suspension
    Last Post: 04-22-2005, 11:20 AM
